09-14-2018, 11:12 PM | #26 | |
But Found Her 25yrs Later!
Re: Crate GoodWrench 350 Questions
09-14-2018, 11:25 PM | #27 |
Or a Duramax transplant
09-15-2018, 09:20 AM | #28 |
09-15-2018, 08:47 PM | #29 |
I've been doing research, is it true they built it with really low compression so the engine could use low octane gas?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 09-15-2018 at 09:00 PM. |
09-15-2018, 10:10 PM | #30 |
The goodwrench 350? Yes that is partially true. They wanted a economical engine that could be put in most 1985 and under cars and trucks and pass emission standards everywhere. If the made a 350hp 350, it might not pass some emission requirements.
09-16-2018, 09:45 AM | #31 |
Agreed, mostly stock 283 with 225/75/15 tires and 3 on the tree. 3.08 is great
09-16-2018, 11:24 AM | #32 |
Who's got steelies?
My 78 big 10 is just like yours, stock 350/TH350 and 3:08, and will hold 70 with the AC on using the cruise going uphill with out any trouble.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel Last edited by oldgold70c10; 09-16-2018 at 11:29 AM. Reason: Forgot quote |
09-16-2018, 12:12 PM | #33 |
I agree. I was referring to it loaded AND going uphill. Like with a 1500 slide in camper and another 700lbs worth of stuff inside.
05-10-2021, 12:32 PM | #34 | |
That totally makes sense. I just couldn't figure why they would deliberately build it to be a dog - It needs to pass emissions in every State in every car. Here in Oregon anything around 1974 and older doesn't have to do an emissions test.
05-10-2021, 01:34 PM | #35 | |
https://www.mortec.com/location.htm
02-09-2022, 06:10 PM | #36 |
Is a stock gm Goodwrench 350 good 'as is' for a truck application where you are mainly concerned about fuel economy and low end torque?
02-09-2022, 08:49 PM | #37 |
Mediocre. I had to swap to vortec heads, cam and headers so it could get out of it's own way.
02-09-2022, 09:03 PM | #38 |
I think its fine however, these days a roller cam seems to be the hot ticket because of the new oil. I do fine with a 283 for just driving around so that 350 should be great for driving around. Especially if you have dual exhaust and a nice aluminium dual plane intake. I dunno I've seen many a smokey burnout from a stock Goodwrech 350 in a classic truck.
02-09-2022, 09:50 PM | #39 |
ZZ shortblock, summit vortec heads and a dual plane intake is the ticket right now
Tags |
350, crate, engine, goodwrench |
