08-24-2010, 08:35 PM | #26 |
Re: rustoleum paint jobs
rustoleum is fine for a beater ... but you're in for a BIG surprise if you ever want to take that rustoleum crap off and put on a real automotive coating.
08-24-2010, 08:54 PM | #27 | |
Redefining LowBudget
to be honest mine was painted with black rustolem when I got it ...and a crappy job at best..it sanded off with some 80 grit pretty easy..and if you ever choose to do it with automotiuve paint there are always options like soda blasting |
08-24-2010, 09:33 PM | #28 |
ok
08-28-2010, 10:14 PM | #29 |
Tractor Supply Company has the Valspar hardener And Valspar Paint
08-29-2010, 12:48 AM | #30 |
08-29-2010, 11:39 AM | #31 |
well men what I can tell you is that the local Lowes does NOT carry valspar that can be tinted....I'm going to do a check online to see if they can at some of the near by stores....both of which I have to drive by a tractor supply???
But the nice young lady did a scan of my ashtray and the Copper my truck was it may very well be again!!! on a side note maybe someone could snap a pic of of discribe where the cut lines are.....my plan is the bottom of the A pillar and even with the chrome under the rear window...just not sure where or if the doors get invovled and if the white roof wraps over the rain gutter in the door jam??? Help?? |
08-29-2010, 11:46 AM | #32 |
hey Nbpro I noticed there a bit more that Lowes (@ $31) and I don't see if they can tint it???
08-29-2010, 12:15 PM | #33 | |
I disagree with the statement that you have to take it all off to put on a quality automotive paint. This stuff is Synthetic or Alkyd Enamel paint. When fully cured, whether hardener was used or not I would believe this stuff was as good a base for another paint job as any primer would be... As long as proper prep such as sanding and de-greasing was done PRIOR to the Rustoleum paintjob I see no reason why it isn't just as good a primer for a later paintjob... You'd want to block it, then lay on epoxy to seal it, then your primers...Of course starting with bare-metal is always best when you can do so but nobody says you have to... They way my daughter drives, I think she's getting Tractor Supply paint on her 4Runner with hardener !! |
08-29-2010, 02:56 PM | #34 |
08-29-2010, 03:20 PM | #35 |
I'm not sure if they can tint it or not. Never actually used the paint itself, just the hardener. The reason it's more expensive is it's actually automotive restoration paint for tractors and other farm equipment. Pretty durable stuff from my understanding. I'm not sure if Lowe's would carry something of that nature. I think their stuff is mostly latex isn't it? That would work on metal, but other than that, I have no idea of how it would hold up.
08-29-2010, 03:39 PM | #36 |
Something i'm going to try. I have a couple of small bags of powder candy and pearl. I'm going to mix with some Rustoleum and see how it turns out. Do a test panel or something. I bought the stuff at this link. Fairly cheap.
08-29-2010, 04:12 PM | #37 |
funny you say that I saw some gold flake that I thought would go well with the copper???
And it seems that some of the Lowes will tin OIL based paints..but the one nearest me is kinda small....I may have to check out TS on the way by
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
08-29-2010, 09:46 PM | #38 |
Cruzin
why not go for it, it's only metal like anything else and a high $$$ paint job won't get ya home either i have noticed that rustoleum is makeing some automotive primers and such and engine paints in lots of colors so.........
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
08-29-2010, 09:52 PM | #39 |
gold flake is hard to paint, or any flake as far as that goes. the stuff im talking about is a very fine powder. almost like powdered sugar. you just mix it into your thinner, reducer, etc. mix paint like you would normal spray it. i've used it with enamel. turned out pretty nice. i didn't have a paint booth and got trash in everything. having to repaint it.
08-29-2010, 10:00 PM | #40 |
I just looked at that it looks like it has to be mixed with a clear coat??
08-29-2010, 10:11 PM | #41 |
Grandpa in the rustmobile...
hey hottrucks, how did you do your truck? I really like the red primer lol, my truck is multiple colors. Run us through yours please? everything from prep to spray.
Whered you get the paint? Rattle can or spray sprayed? what conditions etc? thanks, you may have a twin with white roof
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-30-2010, 07:37 AM | #42 |
check my build and you'll see I sprayed it in the yard and the primer is from Napa $43 a gallon...it keepit one color and no one has noticed when I put the fender or bed o it
08-30-2010, 08:09 PM | #43 | |
it can be added to just about anything from what i've read.http://www.paintwithpearl.com/pearluses.htm Last edited by nbpro; 08-30-2010 at 09:05 PM. |
08-30-2010, 09:01 PM | #44 |
Here's my plan
Remove bumpers, grill, lights, mirrors, ect Sand Bondo Sand Primer Sand fine PAY to get it painted and clear coated Re-Install bumpers, grill, lights, mirrors, ect Save lots of $$$ |
08-30-2010, 09:20 PM | #45 |
sounds like a plan around here a single stage paint job can cost anywhere from $300 to $500. And that's with the body work already done.
08-31-2010, 09:00 PM | #46 |
For the money involved it seems worth the risk, depending on the vehicle and the expectations. Did everyone read the HAMB link? post #113 click the link and read up on the Corvair. Pretty cool.
For as many haters it seems there are also lovers. Back to the expectations. Paint remover may be the ticket to removing it if needed later down the road.
"I feel the need for speed!"... as soon as I am done with my nap. |
09-01-2010, 08:35 AM | #47 | |
Be sure to read post #92 as well ....
09-01-2010, 07:32 PM | #48 |
Active Member
Here's the paint I was talking about from Lowes. It is a tintable enamel.
http://www.lowes.com/pd_83060-4-044....ductId=3179251 |
09-01-2010, 08:04 PM | #49 |
Sweet now i know what to look for
on a side note I went to Shewood williams today...and asked what they had and they where real helpful till I slipped and said something about the color on my truck then it went down hill fast....but they also have a tintable oil base...get aload of this only by the quart in new hampshire but if I drive 2 miles to vemont I can buy it by the gallon??? |
09-01-2010, 11:44 PM | #50 |
Check out the hood here.....http://www.meguiarsonline.com/forums...ad.php?t=40341
If you don't mind BIG surprises in the future by using this stuff you might also want to look here.....http://rolledon.forummotion.com/
Thread Tools | |
Display Modes | |
