03-26-2018, 12:38 PM | #26 |
Re: Lifter Tick after rebuild
Yes I like their oil also, I chose Valvoline products due in part to being readily available at the chain box stores.
I would have not thought the pushrods and valve rockers as a cause. Nice job getting it back together. |
03-26-2018, 07:41 PM | #27 |
One of the First
Thanks - it been a while since I actually worked a motor problem. Knock on wood, all my stuff runs good. Last summer, I lost a ring in the OE motor on the Blazer, it was already punched at 40 over from the last rebuild in 2006, it has been my DD since 2005. So, with the help of the machine shop, found the right 010 block, spec'd it out to 9.87 compression /375 HP. The only thing OE inside that motor is the crank, rods and the carb on top. The crank was/is in perfect shape (good oil), everything else is aftermarket. So it can be done. But, setting up the lash, I remembered that old engine builder would put a dot on the pushrods near the rocker arm. Then he would see if them turned slowly when running, that was a indication the tension wasn't to great or any abnormal movement. If you see in the picture, the yellow dot on the pushrod, that is what helped me figure it out and ensure it was put back together correctly. I guess that is what you can call "Old Skool".
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
Thread Tools | |
Display Modes | |
