Old 06-21-2013, 08:27 AM   #201
Claytona08
Claytona08's Avatar
Re: Project Platinum C10
I got the truck dropped off at the front end shop today to have it aligned. My tires came in yesterday so I got a picture of them while I was dropping off the truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=580955
http://youtu.be/JYoQJYTXKqI
1984 Chevrolet Scottsdale C10 "Project Platinum C10"
1971 Chevrolet Chevelle "Project Car"
Claytona08 is offline   Reply With Quote
Old 06-21-2013, 08:33 AM   #202
Claytona08
Claytona08's Avatar
I have a problem that I hope some of you can help me with. Prior to installing the drop kit it asks that you take dimensions from the center of the rim to the fender. I did this and the truck was sitting 1/2" higher on the front passenger side. After looking at the truck the cab looks to be tilted. After installing the lowering kit the problem still exists. I climbed under the truck yesterday and the bump stop on the front driver side is closer to the upper arm than the passenger side. I took some pics to get everyones input.
Old 06-21-2013, 08:42 AM   #203
SeTx67
SeTx67's Avatar
In my past experiences most vehicles I've owned have never been perfectly level. Just taking a guess (cluelss really) at why the cab doesn't line up with the bed could be cab mounts. I have zero experience with 73-87s.
You're sitting really close to the bump stops. Can they be trimmed down some so you're not hitting them on every little bump?
SeTx67 is offline   Reply With Quote
Old 06-21-2013, 08:47 AM   #204
SeTx67
SeTx67's Avatar
Originally Posted by Claytona08 View Post
Not yet. I still need to have the front end aligned. The paint shop wants me to bring it by so we can go over it one more time and I can pick out the paint colors and get a exterior seals / trim list from him.
Just giving you a hard time . You're actually moving along at a good pace. If you still want metallic paint check out silver ice metallic, black granite metallic and black ice metallic. Can't wait to see it painted
Old 06-21-2013, 08:49 AM   #205
Claytona08
Claytona08's Avatar
I'm not sure if I can or not. Hopefully someone will chime in with some input.
Old 06-21-2013, 08:51 AM   #206
77ChevySharkBite
77ChevySharkBite's Avatar
There naked I don't want to see that!!! my try at truck humor I shouldn't quit my day job huh? I like the tread definitely nice!!
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 06-21-2013, 09:09 AM   #207
Claytona08
Claytona08's Avatar
Haha thanks!
Old 06-21-2013, 10:56 AM   #208
cyclefreak207
cyclefreak207's Avatar
that one is a lotttt closer... Did you replace both shocks? looks like one is pretty worn/dirty in one picture... could that be the difference we're seeing?
86 Short Bed Build
I don't always downshift when I want to change lanes... But when I do, I make sure it's next to a prius so they know I'm hurting the environment!
cyclefreak207 is offline   Reply With Quote
Old 06-21-2013, 11:19 AM   #209
Claytona08
Claytona08's Avatar
They are both brand new. I got some grease on it...lol
Old 06-21-2013, 11:37 AM   #210
cyclefreak207
oh lol. well that's strange the way it's sitting like that...
86 Short Bed Build
Old 06-21-2013, 02:18 PM   #211
Claytona08
Claytona08's Avatar
Someone told me to try and turn the the springs and see if it makes a difference.
Old 06-21-2013, 03:02 PM   #212
cyclefreak207
I would think the bottom of the springs sit level no matter how they're turned? Unless there's a groove they slide into.
86 Short Bed Build
Old 06-21-2013, 03:52 PM   #213
Claytona08
Claytona08's Avatar
From what I understand where the top of the spring sits it is dished and slanted (if that makes sense) and can affect the way the truck sits.
Old 06-21-2013, 05:04 PM   #214
bohmankid
bohmankid's Avatar
There should be a groove for the spring to sit in a certain postition. It's probably very subtle. My truck sat differently depending on which way the springs were positioned.
bohmankid is offline   Reply With Quote
Old 06-21-2013, 07:13 PM   #215
Sodell
Sodell's Avatar
yea, I would check the springs the top has an oval shape and one of them might not be seated correctly.
Sodell is offline   Reply With Quote
Old 06-21-2013, 07:37 PM   #216
SeTx67
SeTx67's Avatar
Check it before the alignment if possible. I hope it's something simple like that
Old 06-21-2013, 07:45 PM   #217
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Looking at your bumpstop pics, it almost looks like you have two different sized springs or lower arms with different drops in front. If you want to troubleshoot, you could always take them out and switch sides to see if it leans to the other side. It doesn't look like it leaned that bad before, or at least I don't see a picture where I can tell it does.
killthewabbit is offline   Reply With Quote
Old 06-25-2013, 09:12 AM   #218
Claytona08
Claytona08's Avatar
This pic is prior to the lowering kit being installed. I will try and turn the springs in the buckets to see if I can adjust it out.
Old 06-25-2013, 09:14 AM   #219
Claytona08
Claytona08's Avatar
I will try and turn them in the bucket to see if that will make a difference.
Old 06-25-2013, 09:21 AM   #220
Claytona08
Claytona08's Avatar
Here are a few pic I took yesterday.
Old 06-25-2013, 09:52 AM   #221
Claytona08
Claytona08's Avatar
Notice that both front driver and passenger lowered 3 1/2" and that both driver and passenger side rear lowered 4 1/4". I need to take a new pic of the bump stops as they are similar now that the truck has been aligned.
Old 06-25-2013, 10:09 AM   #222
SeTx67
SeTx67's Avatar
I really like the new stance. When are the new wheels going on?
Old 06-25-2013, 10:19 AM   #223
Claytona08
Claytona08's Avatar
The wheels and tires are sitting at the tire shop. The paint and body shop told me to wait until after the truck is painted to install the rims so they won't get dirty and dust all over them while it is at the paint shop.
Old 06-25-2013, 10:35 AM   #224
SeTx67
SeTx67's Avatar
Good call on waiting on the wheels. Although I'm sure it'll be tough to wait
I'll be stripping down my interior possibly tomorrow or next Tuesday and getting it ready for paint
Old 06-25-2013, 11:05 AM   #225
Claytona08
Claytona08's Avatar
How much is it going to cost you to get the interior painted? Is it just the dash getting painted or what?
Thread Tools
Display Modes
