Old 08-31-2015, 11:04 AM   #1
Dodge68charger
C10 frame stiffening channel iron?
Does anyone company sell custom bent channel iron that fits inside the frame to stiffen it when shortening a c10 frame. I saw a write up on a c10 that i think hot rod magazine did and they used the channel for extra strength. They said the name of the company that sold them but i cant find the article. Thanks
Dodge68charger is offline   Reply With Quote
Old 08-31-2015, 11:43 AM   #2
cooperhw
cooperhw's Avatar
Re: C10 frame stiffening channel iron?
I saw that too, but can't remember who it was. Sorry.
I use 1/4" plate inside and out with 8- 7/16" grade 8 bolts on each side over the grafted/welded frame rail. Bit of an overkill, but never have to worry about it failing either.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 08-31-2015, 12:08 PM   #3
Swar
Swar's Avatar
Early Classic Enterprises sells them.
Swar is offline   Reply With Quote
Old 08-31-2015, 01:50 PM   #4
Taibo
Forgot about those guys! Frame stiffeners. $35.00.
Taibo is offline   Reply With Quote
Old 08-31-2015, 02:34 PM   #5
Dodge68charger
Thanks guys. I ll check them out
Old 08-31-2015, 05:14 PM   #6
1968aj
I saw these in brothers or lmc catalog. Cant remember which
1968aj is offline   Reply With Quote
Old 08-31-2015, 05:46 PM   #7
1972RedNeck
1972RedNeck's Avatar
Be careful with those. You need to seal them so water and junk can't get betwixt them and the frame to start rusting.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 08-31-2015, 05:55 PM   #8
Taibo
Weld through primer does that job satisfactorily!
Old 08-31-2015, 09:31 PM   #9
Dodge68charger
Will weld thru primer hold up if i get the frame powdercoated after. Thanks
Thread Tools
Display Modes
