09-01-2016, 09:46 AM | #1 |
Junior Member
Looking for pics of Western Chassis reacr shock relocators installed.
Pic please as the product did not come with installation instructions and I am having some one else do the install who is telling me the new brackets kneed to be ground down to fit properly. I can not get Western Chassis to get me an answer for the last three hours.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 09-01-2016 at 02:22 PM. Reason: add info |
09-01-2016, 03:06 PM | #2 |
Re: Looking for pics of Western Chassis reacr shock relocators installed.
I have some installed on my 74 im just away from the truck now. its pretty straight forward install. they sit inside the current shock mount, bolt on the top each side and 1 bolt thru the back. the rounded part at the bottom is where the bottom of your shock bolts to. I believe you supply that bolt or use your old bolt.
09-01-2016, 03:31 PM | #3 | |
Junior Member
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
09-01-2016, 03:35 PM | #4 |
mine where a tight fit I just hammered them in.
09-01-2016, 03:47 PM | #5 |
Junior Member
[QUOTE=midnight rambler;7701280]mine where a tight fit I just hammered them in.[/QU
Are you talking about having to hammer them in the existing shock mount? If so that is what he might be talking about needing to grind.
09-01-2016, 03:59 PM | #6 |
yes its a tight fit
09-01-2016, 04:02 PM | #7 |
Junior Member
Thanks again. Did you use their front relocator kit?
09-01-2016, 04:06 PM | #8 |
Junior Member
Without the truck in front of me it looks like the front relocators will be hard to install with inner fenders on the trucks. I might be wrong.
09-01-2016, 05:09 PM | #9 |
09-01-2016, 05:18 PM | #10 |
heres mine but not my truck
09-01-2016, 05:55 PM | #11 |
Junior Member
Thanks for the pic.
I am talking the about rears. Apparently I have shock extenders for which no instructions came with the package. This is the email I got from them. Shock extenders. Unfortunately, I didn't have access to your invoice until now. I see that it's not a relocation kit but an extender. We don't have instructions because those a direct replacement for the existing shackle...however, perhaps we should. I am searching for something that will help. and will send it to you asap.
09-01-2016, 06:00 PM | #12 |
Junior Member
The front looks like it is going to require the inner fenders to come out. Just a bad design. I should have done more research.
09-01-2016, 06:02 PM | #13 |
how tight are they ? when I installed mine. I had to spread them a little. I just spread them with a adjustable wrench. then I drove them home with the hammer. bolted right up. post some pictures. ill get a picture of my rears tonight.
09-01-2016, 06:03 PM | #14 |
09-01-2016, 06:04 PM | #15 |
Diggin The SquareLife
jus spread them apart....the ones I had just went right in....its simple to bolt them on
09-01-2016, 07:50 PM | #16 |
Junior Member
You guys talking about rears
09-01-2016, 07:59 PM | #17 |
Junior Member
This is the shock extenders I am talking about.
09-01-2016, 10:06 PM | #18 |
Not the best pic but this should give you the idea. Side holes in bracket go through original shock mount holes.
09-01-2016, 10:24 PM | #19 |
My picture not much better
09-02-2016, 12:00 AM | #20 |
I made my own, based on pictures I found. Same idea:
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
09-02-2016, 09:38 AM | #21 |
Junior Member
Once I got to the shop to lend a hand it was painfully obvious what I could not understand thru text. The top of the bracket does not have the indentions at the top like the ones in my picture above in the previous post. The bracket will need to be ground down on the top to allow full extension. I will also have to re-drill the hole to get it to line up as well. I do not recommend their brackets. They should have been a complete bolt one installation with no mods necessary. I am returning the front extenders as well because you have to drill holes in the top of the frame and that is not accessible without removing the inner fender. There are better designs available. I will post some picturess later but here is a sketch.
09-02-2016, 09:59 AM | #22 |
You shouldn't have to grind anything off the brackets, but you will have to open the hole size on the top hole of the original mount. Then the new bracket should bolt up with plenty of clearance. I'll get you some pics tonight if needed.
Follow me on Instagram: @midtennc10 Youtube channel: Midtennc10 |
09-02-2016, 10:10 AM | #23 |
I had one pic on my computer of the bolt hole you'll need to open up, I think from 7/16 to 1/2". In the pic you also see another problem you may have to address with the bolt hitting the leaf spring plate. About a 1/8" of clearance is needed on a 4 leaf pack and about 1/4" is needed on a 3 leaf pack.
09-02-2016, 11:21 AM | #24 | |
09-02-2016, 11:45 AM | #25 |
Junior Member
I see. If we open the bolt hole it will allow the bracket to slide down and it will clear the axel housing. It was already installed when I got there and I didn't think that all the way thru but makes perfect sense.
Thread Tools | |
Display Modes | |
