12-02-2018, 08:47 PM | #1 |
small journal 327 build
hey guys, im currently working on an engine build and would like some input on cam choice. the build itself is going to be mostly stock. its a small journal 327, forged crank, new rods and pistons. the pistons are flatops with valve reliefs. all machine work has been done and everything is fresh. the block has been bored 30 over, giving a 331ci. since this project is being built for fun, im not dropping a lot of money into it. i will be using the stock 462 heads again, they also have been cleaned and trued up. i will be using an aluminum dual plane intake and a 600 cfm carb. the idea of the build is to place in a lightweight car like a chevy 2. this will be a 3 speed auto (th350) and 3.73 rear.
with that said, i have been toying around with the cam choice. i will be staying with the flat tappet. ive been thinking about some such as the 268H, xe268, and L79 (#151). im obviously not looking for "500 hp" but want a good little street engine with good low end pull. i have used these cams in the past, but never in a 327. any suggestions would be greatly appreciated.
12-03-2018, 11:18 AM | #2 |
Re: small journal 327 build
THe 268H is the largest I would go, would prefer the 260H for the 331. I would not use any XE cam...268H is OK for a 350, and great for a 400!!!
12-04-2018, 12:27 AM | #3 |
60-66 Nut
If you are wanting good low end, the HE268 may be ok but the XE268 may be a bit much.
12-04-2018, 10:07 AM | #4 |
I have an engine pro #1991 in my 327 close to your setup in my 69 C-10 love this cam. This cam pulls great
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
12-04-2018, 04:48 PM | #5 |
Im in the process of building a small journal 327 myself...One thing i did notice is that there are not many options for pistons that are not the "rebuilder" pistons that put the piston wayyy down in the bore and you end up with a motor that has a quench of > .060 and horrible compression ratio. I ended up going with speedpro H660cp30 pistions. They put my pistons .025 in the hole (undecked block) and will allow me to maintain around a .040 quench. I am running aluminum trick flow heads and went with a .458 lift cam with 284in/284ex duration(218 @ .050) and a 110 lsa. Im using 1.6 rockers so that will effectively make my lift more like .498...
12-04-2018, 04:55 PM | #6 |
Fabricate till you "puke"
Most of these builds , are for a heavy truck.....in a lite weight Nova/3.73 gear, with a little looser converter I think you can use a little more cam I ran an XE 268, in my 383, & I do agree that it might be too much for the 331 , for your app. I would suggest an XE-262,or Lunati equivelant & hit your stall around 24-2500....should be fun to play with.... Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-05-2018, 08:56 PM | #7 |
The L79 cam is always a good choice, but on the Corvette boards the preference is for the L46 cam which is similar in overall valve events but has different ramps. For a budget build in a lighter car this looks good to me.
http://www.competitionproducts.com/H.../#.XAhznGhKjIU
12-07-2018, 05:21 PM | #8 |
That L-46 camshaft , that MIKE C listed is one bad azz street cam! However, I feel that the modern profiles on the cams , show us more? The newer cams , show more vacumn/idle quality....& more low end response, & dont really mess with the top end too much? Not here to argue/or fight....just my opinion....longhorn
12-14-2018, 06:56 PM | #9 |
With smaller displacement in heavy vehicles I've always built like it was a 4x4 and they run out great!
Thread Tools | |
Display Modes | |
