12-11-2018, 05:56 PM | #1 |
1990 chevy bucket seats swap
i have a 1990 chevy with the bench seat in it, my brother in law has buckets and center console I would like to swap in. anyone done this before? is it a direct bolt in?
thanks |
12-11-2018, 07:26 PM | #2 |
Re: 1990 chevy bucket seats swap
You'll have to drill holes for the buckte's inner mounts and the center counsole, but it is easy to do. I don't think the floor has any premade marking on it where you will need to drill, so just measure twice or so with the brackets, drill, bolt them in. I would use a hard thick washer or plate for the inner seat bolts to give it more strength in the floor mount support.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 12-11-2018 at 08:13 PM. |
12-11-2018, 07:32 PM | #3 |
thanks ill try that
12-12-2018, 09:10 PM | #4 |
I swapped buckets in my 94 that came from the factory with a bench. Use the risers as a template. I used thick plate steel underneath the body for reinforcement. The floorboards are actually thin
Posted via Mobile Device |
12-13-2018, 01:11 PM | #5 |
my old 96 crew cab floor had the threaded nut tabs welded on the bottom of the floor already . i just had to pop the hole threw the tin floor to get to them .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
12-22-2018, 05:51 PM | #6 | |
I used 92 seat frame as I didn’t have the wiring for the lower seats and they still lined up.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
Thread Tools | |
Display Modes | |
