09-10-2020, 08:14 PM | #1 |
Can swap
Can you swap cam with engine in truck. 70 with AC
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
09-10-2020, 08:24 PM | #2 |
Re: Can swap
You'd have to pull the radiator and the AC condenser, probably the core support, and maybe the grill.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
09-10-2020, 10:51 PM | #3 |
Re: Can swap
That's what I thought. I was hoping someone had been able to do it with the AC condenser in. Per my measurements I didn't think it would work. Probably easier to pull the motor than pull the front end apart and redo the A/C
09-11-2020, 08:26 AM | #4 | |
Re: Can swap
I don’t think your condenser is solid mounted to the rest of the a/c stuff. Should move out of the way. Why the cam change? Do you have pics of your engine with a/c stuff. |
09-11-2020, 11:17 AM | #5 |
Re: Can swap
I put in a SP350/357 GM crate motor earlier this year. Didn't realize a cam with a 108 LSA (215/223 duration) would not really idle very smooth. I've pretty much decided that I'll give up a bit of HP at the top end for more torque at the bottom and a smoother idle. Don't have any pictures, but it's all stock as far as the AC goes.
09-11-2020, 11:54 AM | #6 | |
Re: Can swap
A 110 lobe separation is what most street cams are ground on for good idle, and low end power. I would get a model with this lobe seperation, and no more then 112. Unless you build a engine to swing to 7500 rpm. Lobe seperation has a tendency to just move the power up in the higher end by about 500 rpm to maybe a 1000 on a wilder cam. This is why I prefer the 106's since I could get 20-30 more hp/tq from 2500 till 4500 roughly to mess around with. I also enjoy the rough idle in a performance build. |
Thread Tools | |
Display Modes | |
