Senoir Member
Parts washer solvent
What solvent do you use in your parts washer?? Mine is in an area with welding & grinding. What do you recommend?? Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
Re: Parts washer solvent
Well, I'd definatly recommend something that's non-flamable. I don't have a washer, but for cleaning parts I always use "paint thinner" from the paint dept. the type you can buy almost anywhere. Basically it's a non flamamble solvent. Comes in qt. gal. and some places 5 gallon pails. It cleans grease good, isn't too stinky, doesn't eveaporate too fast, drys your hands out a bit, but doesn't burn the skin off. It doesn't affect dry paint, and is fairly easy on plastics & rubber too. Whatever you use if ther's sparks around, probly best to keep it coverd.
I got a bench seat baby, you don't have to sit over there. |
its all about the +6 inches
We use about 30 gallons of mineral spirits and a gallon of ATF to help keep your hands some what not messed up.
I use mineral spirits in mine.It doesn't leave an oily film on parts that I want to paint like the kerosene I used to use and it cleans just as well.I also started using the nitrile gloves from harbor freight keeps your skin in good shape and they're disposible,and cheap enough.
![]() Join Date: Mar 2003
I use K1 kerosene, afterwards when it's dirty I can mix it in with my waste oil for disposal.
Check your local fuel distributers, I have a local oil company that sells bulk fuel and still carries parts washer solvent. Its about 4 bucks a gallon, I try to take care of it and make it last a long time.
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
Senoir Member
Sounds like the mineral spirits may be the way to go....less cleaning before painting. Thanks.
![]() Join Date: Sep 2005
I use a very strong concentration of Dawn dish soap...about 16 oz per 10 gals of water. Let your parts sit in that for a week, and when you pull them out, all that oily greasy stuff is soft as mush. Give them a quick brushing and they're good as new. Then if you want to use the mineral spirits...any good painter will always wipe the car down w/a degreasing agent....now is the time for that. Afterwards, if you let your water sit, the oily crap comes to the top, and you can scrape it off, then dump it, so you don't get the EPA folks upset.
1968 Custom SWB, 327/3 speed OTC 1969 CST LWB, 402/400 1970 CST LWB, 402/400 1970 Sierra Grande LWB, 350/350 1971 Cheyenne LWB, 350/350 1972 Cheyenne Super LWB, 402/400 1972 Sierra Grande LWB, 402/400 1979 Silverado LWB, 350/350 1984 Suburban 1990 454 SS 1991 Silverado, X-cab, 4.3/5 speed Getrag 2005 Silverado Crew Cab Corvettes: 75, 77, 78, 93, 96 Last edited by 73737373; 11-12-2005 at 05:58 AM. |
Cantankerous Geezer
Follow Jeff's recommendation and get solvent. It used to be sold under the name Stoddard Safety Solvent. The safety is the fact that it doesn't flash like mineral spirits, you can throw a lit match in it and the match will burn out. It is flammable, which means it will burn when it gets hot enough. I started using it at a shop in 73 and fell in love. Far better than kerosene for cleaning. I buy mine at a local co-op, there's also a bulk dealer in the area that will deliver. At the museum we usually change the solvent out annually, we use it every weekend. My washer at home I filled 5 years ago, it is just now needing changed.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Old Skool Club
![]() Join Date: Jun 2001
Back in "the day", I worked for an ESSO dealer....pre-EXXON. They had a solvent that was sold, called Varsol. Last time I bought any was in '75. It was pretty good stuff.
Since that time, I bought Gunk, in the 1-gallon can and used it full strength. I also bought some stuff called Tyme, also in a 1-gallon can, but also available in a 5-gallon bucket, with a parts cleaning basket. Oh, it only came with 3-gallons of cleaner. Both Tyme and Gunk were used where I worked to clean carburetors for rebuilding. Probably the best part of the carb-cleaning equipment was the container that used air to raise/lower the basket continually during the cleaning process (1 hour), which was also on a timer. But, that was also back in '75-76. If you have one of the recirculating parts cleaner sink/pump/filter equipment, check with Safety-Kleen for some of their solvents. Don't use gasoline, because of the flammability of the vapors. Kerosene is good for cleaning tar off of vehicles, but it does leave an oily film.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
We still use stoddard solvent and works great. You will have to go to a petroleum distributer to get it more than likely.
Mike
Mike Redpath Last edited by Musclerodz; 11-12-2005 at 05:34 PM. |
Senoir Member
Never heard of stoddard, will do some checking around. Thanks for all the great input. Would have to learn alot the hard way without this board. Greg
Stoddard solvent is the same thing as Varsol.
Senoir Member
Thanks Jim, I've heard of that.....HAHA.
#15 |
We have always used diesel fuel because living on a farm that was alway around but it does leave a film so if you plan on painting something it isn't the way to go.
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons ![]() |
