Old 08-17-2002, 10:59 PM   #1
alta-aj
Gear Noise
I have a 69 Chevy 4x4 with a Rockwell T221 linked to an SM465 4 speed. Both have just recently been rebuilt but ever since I can remember (and that's a long time cuz my dad bought the truck brand new) they have been noisy when travelling above 45 mph or so. Although I think it is the T.C. that's the culprt< I'm not sure. I just have standard gear oil in these boxes at the moment. I'm wondering if any of you have recommendations on a type of oil that might quite things down some?
alta-aj is offline   Reply With Quote
Old 08-18-2002, 02:34 PM   #2
6869704X4
Turn up the radio.hehe
Those are some noisy trans.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 08-20-2002, 09:43 PM   #3
69gmcfleet
My truck has the same setup and everything is stock and works great, but it still has a noise to them at speed. I think it is mostly my tranny though. I think it is the nature of the beast.
Like he said, turn up the radio!
Jeff
'69 GMC K2500 LWB, '74 350/SM465/Rockwell T-221, cnD44/ffD60, 3.73 gears, 31" BFG's
(originally had 305ci V-6)
'05 VW golf
'84 HD Sportster XLX
'68 GMC K2500 parts beast
69gmcfleet is offline   Reply With Quote
Old 08-20-2002, 11:53 PM   #4
palallin
I don't have all the answers, but aren't the gears in the Rockwell straight cut? If so, they will make more noise. . . .
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 08-21-2002, 04:00 PM   #5
Yukon Jack
Yukon Jack's Avatar
No suggestions my way either. I have a 3 speed manual and Rockwell T221 and it's pretty noisy . . . and I don't have a radio to turn up!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-28-2002, 06:53 PM   #6
69gmcfleet
I believe that the Muncie SM465 has damn near straight cut gears also. My truck in 4th gear has a high whining noise to it. I am not sure about the Rockwell case since I never leave 2nd in 4wd. My truck rides way to rough to hit speed. I would say the Rockwell gears are straight cut also.
Jeff
'05 VW golf
Old 08-31-2002, 08:48 PM   #7
alta-aj
Angry Thanks for your input guys.
- I was just hoping that there was a gear oil that could help.
OK, I'll turn the radio up - in fact, just got lucky enough to find an original AM/FM - for $10. There was no slider bar though - it cost me $20! - Now I can 'pump out the tunes!' - ya, right!
Cheers all,
Al
Old 09-03-2002, 09:59 AM   #8
Mike C
Mike C's Avatar
There should be virtually ZERO gear noise from the trans/transfer case in top gear and high range. Both of these scenarios send power STRAIGHT through without any gears carrying a load. Sounds like R&P noise to me. My 465/205 combo is pretty darn quiet on the road (tires and 4.10 are a different story however). Put the transfer case in 4 high though, and who needs an indicator light? You will KNOW it is engaged from the massive amounst of gear noise from the straight cut gears of the 205.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-03-2002, 10:14 PM   #9
GrungyCoin
Prone to gear whine
Rockwell cases the power gets transfered to the idler shaft and then to the output shaft in 2H. The gear whine will be louder when the idler shaft gets wear between the gear and shaft (this causes misallignment therefore louder whine), not too much you can do with it. I fixed mine up good, but it did requier modification and a whole new idler shaft. As far as transmission whine there really shouldn't be any in high gear. Power is transmitted straight thru, the counter shaft is still spinning though, but with no load there should be no whine. As far as lube my '67 GM service manuel says "Either SAE 80 or SAE 80-90 multi-purpose gear lubricant". Ditto that for the transfer case.
GrungyCoin is offline   Reply With Quote
Old 09-03-2002, 10:31 PM   #10
Mike C
Mike C's Avatar
Another reason to lose the Rockwell!
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 09-05-2002, 09:20 AM   #11
mardenmaine
deaden the sound...
my 67 4x4 whines pretty bad too... the loud stereo is ok but some heat shield/ sound dampening material (mines from jcwhitney) has done alot to make the sound levels inside the cab liveable... be sure to buy alot of the material for it takes alot to do an effective job...
mardenmaine is offline   Reply With Quote
Old 09-05-2002, 09:51 AM   #12
palallin
That seems a little extreme: the noise is mechanical music!
