Old 12-01-2005, 05:44 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
header collector sealing problem.
my header collector surfaces seem to be warped. i have aluminum gaskets in there now and no matter how much i tighten them it still leaks. i was thinking of using 2 white paper style gaskets. should i do it? if i do should i use red silicone? should i just get the damn things welded instead (im tempted)?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 12-01-2005, 05:58 PM   #2
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: header collector sealing problem.
Paper gaskets will blow out in no time. I have the same problem. Very tempted to weld them together. I bought a new set of headers for my big block truck that has the ball and flange type collectors. Great design, uses no gaskets and does not leak. I'm thinking of getting a set for the small block truck.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 12-01-2005, 07:42 PM   #3
kaycee
kaycee's Avatar
I have used 2 gaskets before and yes it did work for me but they will eventually leak again.I belive the ball/flange setup is the way to go but I can't afford a new set of header's.The problem is everyone tightens the hell out of them to keep from leaking which warps the flange.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 12-01-2005, 08:17 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
are you running thin alluminum ones, or the 1/4 inch thick dead soft alluminum ones?
Try the latter if you haven't, I have yet to see a header they wouldn't seal. (within reason)
Old 12-01-2005, 09:07 PM   #5
70c10
67-72 Addict!
70c10's Avatar
My buddy swears by the foil type donut gaskets. I recently doubled up the dead soft aluminum ones plus used the copper silicone.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-01-2005, 10:05 PM   #6
crm318
crm318's Avatar
yea im using the thin ones but they arent as thin as a a mr. gasket copper gasket. i really want to weld them but thats pretty permenant. if i use 2 gaskets, should i put selant between the gaskets?
1972 Cheyenne
Old 12-01-2005, 11:31 PM   #7
68Stepbed
68Stepbed's Avatar
If your gonna weld, why not use one of these ball flange kits? They're made by Flowmaster. One end welds to the header collector and the other welds to the exhaust pipe.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 12-02-2005, 12:08 AM   #8
cableguy0
get a set of hooker collectors with the welded flange they are thicker flanges and will straighten out the warped header flanges.then just resuse your aluminum gaskets
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-02-2005, 09:07 AM   #9
ed455
Captain Ed
I cut the flanges off mine and expanded the pipe to slip over the collector. I happen to have a 3" exhaust so it worked for me, but if you are going from a 3" collector to say, a 2.5" pipe, you can use the slip over adaptors. I also use the band styly stainless exhaust clamps. No leaky here anymore.
If you ain't bleedin', you ain't workin'!
1999 C3500 LS 7.4L
ed455 is offline   Reply With Quote
Old 12-02-2005, 05:10 PM   #10
crm318
crm318's Avatar
what is the website for those ball flanges? the only thing is is that i would need them from 3 in o 2.25.
1972 Cheyenne
Old 12-02-2005, 08:29 PM   #11
cst70rocket
" no matter how tight I tighten them, they won't seal"
That's the problem. They don't need to be that tight. Here is the cheapest solution, and it works flawlessly everytime, for years to come. Go to the parts store, and buy some good collector gaskets, 2 sets (4 gaskets) I prefer the fel pro blue gaskets if you can find them. Then go to your local exhaust shop, and buy an extra set of flanges. All ya gotta do is sandwich the extra flange between the two gaskets, and viola!!! No more leaks. Please submit $1 to my paypal account for this info!!! BTW, here is a pic.
cst70rocket is offline   Reply With Quote
Old 12-02-2005, 09:44 PM   #12
SSC's76
No No
SSC's76's Avatar
You suck! I wanted to tell them about that trick.
Yep as cst70 said this trick works! Ive done it a few times with warped flanges and it sealed them up with no problems. This also tends to increase collector gasket life quite a bit since the pipes arent constantly rubbing against both sides of the gasket cutting it from both ends.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 12-03-2005, 03:20 PM   #13
crm318
crm318's Avatar
wow that looks awsome. i think i will try that. thanks for the tip guys.
1972 Cheyenne
Old 12-03-2005, 05:13 PM   #14
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
read the rules. you may only sell or advertise things for sale if you are a contributor
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 12-03-2005, 06:49 PM   #15
68Stepbed
68Stepbed's Avatar
Well, if cst70rocket's idea doesn't work, and it probably will, you can get the ball mount flanges from www.summitracing.com. They make them for all size pipes.
cst70rocket, GREAT tip. I'm gonna try it myself.
Matt
Old 12-03-2005, 09:20 PM   #16
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I need them in a 2.5 and 2.5 I only see 3.0 and 2.5 for a set. Anyone make those?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 12-03-2005, 09:49 PM   #17
crm318
crm318's Avatar
i tried the copper ones. they had the same result as the aluminum ones
1972 Cheyenne
Old 12-03-2005, 10:46 PM   #18
gringoloco
A guy with a truck
gringoloco's Avatar
They can special order direct from Flowmaster. Doesn't cost any extra. I did exactly that. Ball/socket flanges rock No leaks!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-04-2005, 02:28 AM   #19
DroppedZ84
DroppedZ84's Avatar
I've found that with the Hooker's that have the collector flange welded, they never leak.
DroppedZ84 is offline   Reply With Quote
Old 12-04-2005, 03:18 AM   #20
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
I gotta try that gasket trick. My passenger side leaks.
But will probably stay that way till March when it warms up
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 12-04-2005, 12:07 PM   #21
tmcgrawlookalike
i`ve always changed the lip sealing flange over to a hooker type before putting the headers on.it can be done afterwards,but is a pain in the *&%^$#!@?!tack the flange where you want it on the collector end,grind off the lip,run a full bead on the flange,do the same to the reducer,and i`ve always used the hooker header gasket,both head and collector.best if you use new,but i`ve used old stuff too.good luck!!
tmcgrawlookalike is offline   Reply With Quote
Old 02-13-2017, 07:07 PM   #22
JoePublicVA
I have 75 Chevy c30. Same constant problem w leaky flanges. Tried everything except welding which crates another problem if removing headers. Came up with C Flange Bracket. You tube it for complete installation video. Plz comment. Inquiry about getting working model for trial use. No cutting necessary.
JoePublicVA is offline   Reply With Quote
Old 02-13-2017, 07:11 PM   #23
JoePublicVA
I just posted a reply on similar problem. You tube C Flange Bracket. I have 75 c30 same leaky problem till I used this.
Old 02-13-2017, 07:17 PM   #24
JoePublicVA
Nice. Chk out C Flange Bracket on u tube. Works great.
Old 02-13-2017, 07:19 PM   #25
JoePublicVA
Still likely to leak again. Flatten flange and get C Flange Bracket. U tube it
