Old 12-08-2006, 01:04 PM   #1
1969K10
1969K10's Avatar
Short Episode On The Soap Box
so, 'cause I don't know what I should before I get into most projects, I did things back-a$$-wards... Picked up a set of axles from a 76 K20!! Went and got brakes, seals, bearings, and all the essentials for the rear. So, last weekend, I pull the R&P out, and the guts to the ring are trashed!!! busted off teeth on the clutches, and there's some gear driven spring thingy, and the teeth on it are missing where it contacts the appropriate mating gear, which is also trashed!!!!!!!!!!!!!!!!!!!!!!!!! I'm so freakin' pissed!!!! So, I don't have the play money to purchase new R&P for an axle I don't have to spend money on... And if I was going to blow a wad of cash on the beast, I'd buy cab corners & rockers... OH well, guess they'll be sitting in the back 20 for a couple years until I get around to blowing money on them...
I'm done, next in line please...
1969K10 is offline   Reply With Quote
Old 12-08-2006, 01:36 PM   #2
1969k10stepside
Re: Short Episode On The Soap Box
I need a np 205 transfer case and I was going to buy the whole truck for it but it turned out to have a 203 transfer case so I am mad .I will never get it running will all my bad luck.
Rant over.....
1969k10stepside is offline   Reply With Quote
Old 12-08-2006, 06:09 PM   #3
LONGHAIR
Just to save you the trouble/expense when you get to it........
Don't even think about fixing that differential. You have what GM calls a "Gov-Loc". They are junk to begin with. Replace it with a better after-market posi unit and you will be far ahead.
LONGHAIR is offline   Reply With Quote
Old 12-08-2006, 06:13 PM   #4
LONGHAIR
Generally all you need to do is find out what transmission is in the truck. An automatic transmission will have a 203 and a 4 speed will have the 205. When you get up into the early 80's they have NP208 cases. This a totally different slip-yolk unit.
Old 12-08-2006, 07:28 PM   #5
1969k10stepside
It had lockouts so I figured it had a 205 because a model with lockouts had the 205 but it wasnt stock with lockouts.I found a 3/4 ton that has a sm465 that should still have the np205 that I am considering buying.
Old 12-08-2006, 07:47 PM   #6
Zoomad75
K5Camper
Zoomad75's Avatar
14 bolts arent that hard to find in the boneyard. Go find one with the same ratio and get the carrier, ring and pinion gears. Get one without gov lock so you don't end up with the same carnage again.
I'd bet you got 3.73's or 4.10's in your 76 k20 axles which are really common ratios for 3/4 ton trucks. shouldn't be too hard to get a used set. If you do it right you shouldn't have too much trouble to set up the gears in your housing. Don't give up and let those parts rot outside yet.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 12-08-2006, 11:23 PM   #7
1tonswb
1tonswb's Avatar
Im my area you can pick up complete 14 bolts anywhere from $30.00 to $100.00. I got a 4.10 ring and pinion out of a 14 bolt that Im not gonna use. You can have them if you pay for the shipping.
1tonswb is offline   Reply With Quote
Old 12-09-2006, 11:08 AM   #8
Yukon Jack
Yukon Jack's Avatar
I also have a ring and pinion from a 14 bolt that is 4.10. I bought a Detroit Locker from a guy and he went ahead and sent the ring and pinion. I pulled the DL out and put back spider gears from my ring and pinion into the ring and pinion he sent me. Like 1tonswb's offer, you are welcome to have it if it can help you out for just the shipping charge. I'm a bit closer to you then 1tonswb but that probably wouldn't affect the shipping charge too much.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-12-2006, 12:11 PM   #9
1969K10
1969K10's Avatar
Thanks for the offers Yukon & 1Ton. I've got 3.73's in (2) different D44's for the front... got anything in the 3.73?
I've heard bad things 'bout the "Gov-lok", and thought that was what I had. Are there any other options for these 14-bolts? I don't really want to go posi, but it'd be better than having another R&P look like this...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
Old 12-12-2006, 03:20 PM   #10
Zoomad75
K5Camper
Zoomad75's Avatar
DETROIT BABY! Nothing is stronger. It's the cheapest model of the detroit lockers since it only replaces the spider gears in a 14 bolt, not the entire carrier like it would on a D44, 10 bolt or 12 bolt.
The catch is you got to find an open carrier because it won't fit inside one that had a gov-bomb. If either have an open carrier I'd hit them up for it. If not they are not that hard to find in the boneyards. You are going to have to replace it anyway since the gov-bomb went kablooie.
Rob Z.
Old 12-12-2006, 06:13 PM   #11
Yukon Jack
Yukon Jack's Avatar
Sorry, the only spare r&p I have is the 4.10 set.
Old 12-12-2006, 07:09 PM   #12
1969K10
1969K10's Avatar
Do these carriers split at 3.73 & 4.10? If not, I should be able to put my ring gear on a 4.10 set...
Old 12-12-2006, 09:48 PM   #13
ClassicJimmy
FNG to resto/mod world!
ClassicJimmy's Avatar
I'm not sure that is true - I have a 4 spd in my 75 K25 & its a NP203. It's been converted to part time like it should have been in the first place, but none the less a 203. I would think the confusion would be with the 205 & 208 since thay have the same shift patterns - the 203 has from front to back: Low Lock, Low, N, Hi, Hi Lock. Just sharing what little I know.
71 GMC Jimmy - under construction
75 GMC K25 Sierra Grande - under deconstruction
92 Chevy K2500 ECSB - sold
04 Nissan Titan ECSB Off Road - sold & missed
13 Ford F-150 Ecoboost (work truck) - sold
16 Ford F-150 Ecoboost (work truck)
ClassicJimmy is offline   Reply With Quote
Old 12-13-2006, 12:02 AM   #14
1969k10stepside
In my experience it has been that the standard trannys have always just had the NP205 stock.Sounds like the original has been swapped out.I might be right or I might be wrong but all the standard trannys I have seen had 205s,unfortunatly none were for sale for me to buy for the transfer case.
Old 12-15-2006, 09:57 AM   #15
1969K10
1969K10's Avatar
TTT, still wondering...
Old 12-15-2006, 11:58 AM   #16
454_72_4X4
454_72_4X4's Avatar
Although most 4 speed trucks came with the 205, a few came with the 203. I know of a couple mid 70's trucks with auto trannies, (TH350), that have the 205 transfer case also.
My wife's 80 K20 has a TH400 auto and a 205 too.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 12-17-2006, 07:36 PM   #17
LONGHAIR
12-15-2006 08:57 AM
That's why I said "generally"..........there are always a few that are different.
There even a few 4-speed K5 Blazers ('73 up) but you don't see many.
Old 12-17-2006, 08:47 PM   #18
454_72_4X4
454_72_4X4's Avatar
Yep!
Another friend has/had a mid 70's K5 with a 4 speed.
Seen one at a U-pull-it yard earlier this summer too. (Had to snatch the chrome shifter out of it! Haha).
I'm in the process of buying a 72 K5 chassis that has a 4 speed also, (teeitup's).
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
