Old 06-12-2007, 12:51 AM   #1
crm318
Alright Alright Alright
crm318's Avatar
what does a cracked flywheel sound like
i have been having a metal on metal contact sound coming from the flywheel area. its louder in the beginning of a gear and lightens up and then gets loud as it shifts into the next gear. is this a cracked flywheel sound?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 06-12-2007, 01:12 AM   #2
CrashEd
72 chevy
CrashEd's Avatar
Re: what does a cracked flywheel sound like
Pull the cover and make sure its not the torque converter bolts if there tight you should beable to look with a flashlight and see a crack around the crank.
Ed
CrashEd is offline   Reply With Quote
Old 06-12-2007, 04:32 PM   #3
bigtruck81
a cracked flexplate sounds like a lower end knock, ive heard some that sounded like main bearings,others sounded like rods. TC bolts typically sound like rods.,
bigtruck81 is offline   Reply With Quote
Old 06-12-2007, 07:16 PM   #4
RUST
RUST's Avatar
I agree. Mine sounded like a rod knocking, so I got a crate 350 to replace a 305. After removal flexplate was cracked at crank bolts. Anyway, I got a 350.
RUST is offline   Reply With Quote
Old 06-13-2007, 12:30 AM   #5
crm318
crm318's Avatar
well i got under the truck and inspected it with a flashlight. i couldnt see any cracks, however it might be cracked around the crank and not the bolts.
1972 Cheyenne
Old 06-13-2007, 12:44 AM   #6
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
I agree, I have heard them sound just like a rod knocking.
Hope you get it figured out.
RJ22...
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 06-13-2007, 01:21 PM   #7
crm318
crm318's Avatar
it sounds like a dryer with a hand full of pennies. it is loudest at the beginning of each gear.
1972 Cheyenne
Old 06-13-2007, 09:33 PM   #8
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
Are you sure it's the transmission? I've heard pebbles in the catalytic converter heat shield described as you have.
Darrin
1955 Willys CJ-5 all original and the oldest CJ-5 on the road.
2001 Dodge Neon (wife's car)
1995 Jeep Grand Cherokee Limited Edition SOLD
1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD
1993 S-10 4X4 Tahoe SOLD
Sign up with the Contact List
RIP ESLL
Mickey_D is offline   Reply With Quote
Old 06-14-2007, 01:20 AM   #9
crm318
crm318's Avatar
i dont have any emissions stuff. my truck is a 72 cheyenne.
1972 Cheyenne
Old 06-17-2007, 09:57 PM   #10
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Maybe broken vain(s) in the torque convertor?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 06-18-2007, 02:30 AM   #11
mexgrhd68
mexgrhd68's Avatar
RJ22...
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks )
54 caddy 62 series 4 door(younger sons ride, aka 54caddy )
70 caddy 2 door, 89 chevy silverado stepside(older sons rides )
mexgrhd68 is offline   Reply With Quote
Old 06-18-2007, 03:20 PM   #12
screamin_eagle
screamin_eagle's Avatar
had the same problem with my jeep thought it was carbon balls in the cat so i took my handy dandy angle grinder and removed it for some reason I couldnt find any wrench or socket that would fit the bolts. anyway got it put back together without the cat and still had the noise. pulled the trans one day to fix a leak got to looking around and found the crack.
screamin_eagle is offline   Reply With Quote
