#176 | |
Re: How to: Ruin a perfectly good Blazer...
![]() You mean like 2 trucks that are different from each other?. My truck will get a modified version of Porters Dropmember..... so it's custom ![]()
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-23-2007 at 08:53 AM. |
#177 |
On the fast track to nowhere..
Custom or not the Dropmember is hands-down the most well designed piece of engineering you can buy for these trucks.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
#178 | |
Texas Big Wig
#179 | |
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! Last edited by PBFAB.COM; 12-23-2007 at 10:32 AM. |
#180 |
C10 Club Tennessee
yeah, he can spray paint it purple
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
#181 |
Don't lube the ball joints and you can have the "noisy" version
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting Last edited by BACKYARD88; 12-23-2007 at 12:30 PM. |
#182 | |
Señor Member
Don't USE ball joints and you can have the "stiff suspension" version.
#183 |
C10 Club Tennessee
No offense guys, but only the people at Norwood got that joke about the Ball Joints. Actually, people in Alabama could hear the noise in spray bombs ball joints. That sounded dirty.
Sorry for the hijack. Looking great gringo, wish I had the money and more important the patience to wait to do that kind of stuff to my roadster. Too antsy to get it on the road.
#184 | |||
A guy with a truck
![]() Quote:
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#186 |
A guy with a truck
Prolly not for a few days. Family is comin' in tomorrow and apparently there's something important happening Tuesday. I dunno...
![]() I did, however, sneak out to the garage for a few minutes today to mock up the DM to get measurements for the rack notch. Let me just say, this thing is going to look killer ![]() ![]()
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 12-23-2007 at 05:05 PM. |
#187 | |
That's not the mod I was talking about though. The C10-DM for my 68 is getting the shock mounts Porter supplies tweaked to work w/the C-10 Bilsteins I bought for this project. I already have mounts fabbed, but since the DM raises the C/L of the lower a-arm pivots, the upper shock bracket will need to be higher vs. where I have it currently set-up to keep the shock @ the center of travel @ ride-height (lower a-arms parrallel to the ground).
#188 | |
C10 Club Tennessee
So everybody start breaking away when they get truck parts for Christmas. How many times do you think these words will be spoken by guys on this board on Tuesday---"Let me go see what this looks like"
#189 |
Gringo, don't know where i've been... but I'm all caught up now....WOW that is sweeet!
R.I.P. Killer 71 10/26/07 |
#190 | |
A guy with a truck
Now that the holiday rush is over, I can get some garage time in ![]() I only ran into a few little bumps: 1) I am having a small clearance problem at the driver's UCA when it pivots down(truck lifted). I temporarily remedied it with alignment shims. On the new(well, rebuilt) UCAs I will use offset shafts that should give me the needed clearance and use fewer(if any) alignment shims. 2) I don't think my "shortened" steering column mod is gonna work anymore. I will likely have to move it back into the cab a few inches to give UCA clearance for the steering linkage. No biggie it's gotta come out anyway. 3) I will definitely have to clearance the inner portion of the fenders. I was half way planning on having to do it anyway, so no big surprise. I have seen trucks tuck the tire inside without trimming, but they must be running extreme backspacing to do that. I like how it looks now, and it will turn without rubbing, so I will trim the inners to lay. Other than that, the DM just fell right together. I am very impressed with the quality, ease of install, and most of all- the look of it.
#191 |
A guy with a truck
Here you can see the tire/inner interference. I figure I would need at least another inch of BS to even come close to clearing.
Also, the obligatory beer can shot. This was taken with the tires resting on the inners; I am amazed at how much clearance there is under there now. No more dragging A-arms on everything! ![]() ![]() Third one is near ride height with the wheel perfectly centered in the wheelwell. The frame is at ~5.5" off the ground with the LCA parallel to the ground. The rear section of the frame is about 6.5" at ride height, so I've got just a little rake. Perfect. Yeah, I'm happy with this mod. Now to tear it all apart again and clean/paint everything...
#192 |
C10 Club Tennessee
Looks awesome gringo!!!!!!!
#193 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Looks killer wheres the smashed can
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#194 |
![]() Join Date: Aug 2005
![]() ![]() Wish I could get my inners done sooner so you could see if that's the way you want to go, but my plate is full with the rear mods and exhaust re-do... |
#195 |
Nice to see it coming together!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#196 |
Looking good
![]() I'm glad you're doing yours before I do mine. It'll be nice to see some of the problems I'm gonna encounter before I get there. ![]() ![]()
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
#197 |
Tot Roddin'
Man that thing is coming together nicely.... great work gringoloco!!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#198 | |
A guy with a truck
Thanks everyone for the props! I feel like I'm getting closer, but I know there's still a LOT left to be done...
Gotta do a little trimmin', then drink the beer ![]() Quote:
Here's what I played with tonite. I blame Frizzle entirely for this mod ![]()
#199 |
K5-2WD=C5
lookin good! what are you using for the rear disc conversion?
#200 |
Junior Member
CrazyWhiteBoy...... It looks killer man!
