Old 03-15-2008, 04:33 AM   #26
otsenre
otsenre's Avatar
Re: Show your homemade tools
Originally Posted by nyncompute View Post
I'm a little embarrassed showing these in light of the talent we have on this board, but if you're like me, sometimes you don't have the right tool to do the job. So what do you do? Go caveman and make your own!
Example1:
I found it difficult to set the rivets when I rebuilt my wing windows so I got a $1.00 Harbor Fright chisel and notched and welded the setting tool to the end. This allowed me to swing the hammer safely above the frame of window.
Example 2:
I ground a cheap 17MM socket and fashioned a crude spanner to work with the switch bezels.
Example:3 The most shameful of all , I hammered a piece of coat hanger to fit in the electrical terminals to release them from their case.
I know it's not much but I pretty sure these separate me from lower forms of life.
My homemade 1 man cab, bed, stepside bed lift, This thing will easily lift a cab, bed, and turn it upside down and there are brackets for a stepside. This thing has saved me a lot of time and grief.Attachment 344267
Attachment 344268
otsenre is offline   Reply With Quote
Old 03-15-2008, 05:43 AM   #27
RCbowtie69
RCbowtie69's Avatar
cool tools,it;s neat to take something out of a pile scrap and something new and cheap to make a useful tool. keep up the ideals
RCbowtie69 is offline   Reply With Quote
Old 03-16-2008, 03:22 AM   #28
nds1968
nds1968's Avatar
I made these to putty the floor of my bed. The wood blocks worked great.
nds1968 is offline   Reply With Quote
Old 03-16-2008, 04:28 AM   #29
TH53
Guest
Posts: n/a
Guys i have been wanting to make a thread like this i think homemade tools are amazing and i have made several and have alot more on the drawing board. I am going home this up coming week for spring break so ill be able to get some picture of the tools i already have completed such as a dimple maker for floor boards, oil pump primer and other sbc tools.
Old 03-16-2008, 08:40 PM   #30
nyncompute
nyncompute's Avatar
Those are great!
1972 K-10 SWB Cheyenne
nyncompute is offline   Reply With Quote
Old 03-16-2008, 09:36 PM   #31
odog
odog's Avatar
Originally Posted by Sillyoldman View Post
I'm no genius inventor. I did although make a couple items.
We used to call mallets like that Commanders, they work good at persudaing things to go into place.
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 03-17-2008, 12:07 AM   #32
Frizzle Fry
It's only metal
Frizzle Fry's Avatar
I had the sawzall/wirebrush idea too. There are places a wire-wheel just won't reach!
Frizzle Fry is offline   Reply With Quote
Old 03-17-2008, 12:49 AM   #33
DavesRide
DavesRide's Avatar
This one has no pics but is an awesome tool. It's called "Old Ugly." To test for shorts to ground that blow fuses. Instead of keep replacing the fuse, hook a headlamp bulb with some wires to where the fuse that is blowing. If it (battery voltage to ground) is shorted the bulb will light up and protecting the circut by the bulb carrying the load. When you find the short the bulb will go off. Serious, It has been a time saver and a money maker.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched
DavesRide is offline   Reply With Quote
Old 03-17-2008, 01:10 AM   #34
kyull67
kyull67's Avatar
Here's my welding table/cart I just made.
kyull67 is offline   Reply With Quote
Old 03-17-2008, 10:07 AM   #35
El Jay
Gone to greener pastures
That is a most excellent idea!!!!
I've used a circuit breaker, with wire leads & clips, around the blown fuse.
Then you can use a cheap compass to chase the circuit. When the circuit is on, it will deflect the needle.
When you get past the short, no more needle deflection.
This works good on long wiring runs, like to the rear of the truck.
It's not really worth a darn for sh....., ahhhhh, stuff, like up under the dash.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 03-17-2008, 11:52 AM   #36
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
I got this idea from Haynes. I used it to press the balljoint from the steering knuckle.
Loosen the nuts on the pins but donīt remove them. Then put this between the two pins and tighten it til the pins pop out.
I didnīt have a crimping tool for the spark plug wires so I made this for the vise.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 03-17-2008, 03:06 PM   #37
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
that crimping tool is really cool! good for us old geezers that have been turning wrenches since dirt was rock. ya know, us old dudes with carpal tunnel and crs disorder but no, really... sometimes i dont have the hand strength i used to. especially when using a crimping tool, strippers, dykes, or pliers. bottom line, i want one! lol
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 03-18-2008, 09:15 AM   #38
blukangoo
blukangoo's Avatar
Itīs really primitive but it works. If I get to the shop in the next couple days, I will get a side shot of it. Itīs easier to see how it is built and works.
It holds for about 8 wires, then you have to replace the tape.
OK. I got to the shop today and did a little cleaning and got these pictures.
I cut 2 pieces of square tubing and put them in the vise together and
drilled an 8 Millimeter hole. Do this after it is cut.
Taped the bottom of it together and put it in the vise.
I then taped the sides to the top of the vise.
Open and shut the vice to operate the homemade crimper.
My C10 Diary
Our cars:
Last edited by blukangoo; 03-20-2008 at 12:10 AM. Reason: Had to edit the message.
Old 05-14-2008, 12:39 AM   #39
mudmizer
mudmizer's Avatar
Love the blue crimper with the auto open. Perfect.
68 4x4, 454, 4 speed, disk brakes both ends,
Sold my 69 SS396 Elcamino when young & stupid
mudmizer is offline   Reply With Quote
Old 05-14-2008, 01:02 AM   #40
evowerks
evowerks's Avatar
Here are a couple of pics of my homemade bearing puller...for the sm465 tranny
"TRUCKS ARE WHAT WE'RE ALL ABOUT"
69 C-30 flatbed/dump on a '88 P30 chassis
70 C-30 Cab & Chassis http://67-72chevytrucks.com/vboard/s...d.php?t=291544
67 GMC Camper Cruiser cab
73 Gmc K25 Sierra Grande BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=291276
evowerks is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
