04-27-2008, 03:05 AM | #1 |
700r4 lockup plug question ASAP
Ok I'm putting my trans in this weekend and I need to know what two prongs I need to use ones posotive and ones ground from pressure switch. Heres a pic if anyone can make this stupidly obvious It would be nice. I need to try to get this thing in and out of the shop this weekend if possible thanks.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
04-27-2008, 05:07 AM | #2 |
its all about the +6 inches
Re: 700r4 lockup plug question ASAP
you gonna just hook a toggle to it? If you have to jab the brakes when it's locked, it'll stall the engine, and that is torrtue on the converter, as is lugging it in lock up.
Any controller kit should have it all wired up and done right. |
04-27-2008, 05:22 AM | #3 |
This kit comes with a pressure switch that goes into the trans or tapped into the servo cover and has a roll of red wire and a roll of black wire and a terminal for the factory plug but isnt real clear on what wires go where. NO this is not a toggle switch its a pressure switch that locks the converter into forth at a set pressure. this does it all on its own. I just need to know what wires are what on the plug so I can wire it in.
04-27-2008, 05:25 AM | #4 |
My apologies.
And unfortunantly, i am unable to asnwer the actual question. |
04-27-2008, 05:52 AM | #5 |
Thanks, I did kind of word the post alittle funny...
04-27-2008, 08:24 AM | #6 |
Msgt USAF Ret
refer to this web page for lock-up wiring. It gives a lot of tips on lock-up and if you can identify the "A" and "D" terminals on the trans plug then 12 volts goes to "A" and "D" is grounded.
http://purplesagetradingpost.com/sum...o/700R4p4.html
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
04-27-2008, 04:15 PM | #7 |
Thats what I thought but the instructions weren't very spacific Thanks.
04-29-2008, 05:47 AM | #8 |
Oilfield Trash
If you are still wondering about this, post the serial number on the side of the trans, and i can look it up in my manual, and tell you what to do.
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
04-30-2008, 02:26 AM | #9 |
I got it in just not hooked up yet.
04-30-2008, 03:00 AM | #10 |
BAD BOW-Silverado XST
