parts breakin' supercusser
![]() Join Date: Aug 2003
I was rotating the tires on my '65 c10 and when I took the drum off of the right rear, I noticed this black stuff all over the brake shoes:
picture 1 So, if it is the wheel cylinder leaking, I have parts for that... If it is a rear axle seal... how does that work? I read about it in the shop manual, but I'm fuzzy on what to do inside the differential cover and what tools to use to properly make the axle come out. picture 2 picture 3 Any tips or suggestions welcome. Thanks, -W
North Georgia Group
Matraca - my 1965 Chevrolet C10 long wheel base Stepside pickup The House of Woogeroo (featuring the semi-famous Old Chevy/GMC Trucks Parts Vendors list - look under Trucks) |
![]() Join Date: Jul 2004
Re: '65 c10 chevy - rear axle seal leak or wheel cylinder?
Looks like axle seal leak to me. Might as well plan for a complete brake job soon, including new cylinders and axle seals. Axles come out easy, remove rear cover, small bolt holds spider pin, remove that bolt, spider pin slides out, push axle in and remove C clip. Pull axle out, before putting axle back in, polish the seal and bearing surface with some 600 wet or dry sandpaper and some WD40.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
dang... I just redid the rear brake shoes last summer.
It's always something I guess. this is a video to a chevelle rear axle - c-clips coming out. http://videos.streetfire.net/video/1...val_153887.htm Someone, told me that those are 'similiar' to the axle in my truck. Thanks for the tips GreenMachine. -W
North Georgia Group
the pollock
![]() Join Date: May 2008
hey jsut a note DO NOT use wd-40 on any spring period ever
use PB blaster wd-40 eats spring steel and leads to rapid failure... jsut a note good luck
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 www.myspace.com/biohazard_racer http://67-72chevytrucks.com/vboard/s...d.php?t=343538 |
#5 | |
Never heard that before ????????? I know acids can do that.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 05-22-2008 at 11:48 PM. |
the pollock
in my former job it was banned form use in aircraft and weapons (army) because we were using it to be a pins and spring loosener but the stuff started degenerating rapidly and breaking soooo
we got banned from it big old memo and researchstuff said no more.. oh well but "pb blaster" works better any way hehehe
Thanks for the replies everyone.
With working and being in school... I decided to take it to the shop. I figured I'd get it apart, and hit a snag or something and it'd really mess up my schedule. I was seriously pondering doing it myself... but it seems anytime I get that far down the rabbit hole with this truck, I need some basic part and it'll take two days to get it... so everything stops. The fun of a daily driver! Well, at least my folks let me borrow their rides for school and work. Thanks again folks, -W
North Georgia Group
27 8x10 color glossy pictures
![]() ![]() Join Date: May 2004
Although I am not a big WD-40 fan, I have never heard of that either. It is great for it's intended use (Water Dispersion-WD) but somehow it has become many people's go-to nut buster and general lubricant? There are far better products for both.
As far as the original question for anyone else that may find this thread: Gravity is your friend here. If the wheel cylinder leaks, it will drip/run down the backing plate, across the outer axle seal and down to the drum. If the axle seal leaks, it can't get back "up-hill" to the wheel cylinder, so it should stay fairly dry. If the axle seal leaks fairly heavily...and you ignore it for a while, it gets thougher to tell. But at that point, you might just as well take care of both at the same time. The shoes are shot either way, so the only added expense would be the wheel cylinders and they are cheap. Also, if the wheel cylinder is leaking, you will be losing fluid at the master cylinder. With an axle seal leak, you are not likely to ever see a fluid loss. |
simple trick to check for brake leaks : go in the cab and step on the brakes and keep it in , if the brakepedal sinks slowly theres a leak , allso if you need to refil brakefluid more than a few drops theres a leak .
to check if the drumbrake cylinders leak take a small blunt screwdriver and lift the the dustcap a little at the bottom (each side of the cylinder ) if fluid comes out there leaking . simple but effective we do it that way all the time when we need to do a yearly checkup
work in progress: the '77 partstruck will be a driver now with the the airride suspension , porterbuild dropmember , strongarms top and bottom and 22 inch alcoa's , there will be another transmission fitted and an orange paintjob is planned (enamel paint) we have to see when it gets done at the moment things look bleak |
Under-funded project guy
![]() Join Date: Feb 2007
Sounds like an axle seal. It is an easy swap, just be very careful - the bolt that hold in the pin with the spider gears on it sometimes breaks. This is a bad thing. I don't yet know how to get it out at this point without destroying something. The last one that broke on me needed to be drilled out, which ruined the differential.
1972 GMC Pre-resto... awaiting allocated funding. |
A prelimnary report from the shop says there is some damage to the axle shaft... so he is running down part numbers from GM.
I have not talked to him directly yet, but it seems there is that damage, and there were some shims missing from the gears or something. I'll keep ya'll informed... I might have to beg some part numbers off you guys tomorrow. -W
North Georgia Group
if the shaft isnt hardened on the bearingpart they might get away with putting a sleeve over it , most likely the seal has made a groove in the axle so a new one will start to leak in no time as whell .
might just be theres to much play in the diff gears and it needs some more shims
Does anyone have any sources for axle shafts?
I found this one through google: http://www.uspowertrain.com/axlesGM.htm 3893605 <- gm part number my mechanic gave me I also found this one: http://www.drivetrain.com/axle.html Anyone else? -W ---- watahyahknow : it has a groove on both shafts, pitting... carrier bearing has some play... the shim pack was not right and was cutting into the axle... *sigh* -W
North Georgia Group
update:
This is another option I have found: http://www.earlyclassic.com search for: axle shaft Axle Shafts, Replacement & Conversion #02-6369AXL - '63-'69 6-Lug Replacement Axles Only
North Georgia Group
| Thread Tools | |
| Display Modes | |
