Old 05-27-2008, 10:38 PM   #1
muddpile
muddpile's Avatar
stock headlight switch wiring diagram?
I have a stock headlight switch and a generic aftermarket harness. Which terminal does what on that switch? There are 7 terminals and a ground terminal it looks like. The previous owner did the entire underside of the dash in green, black and white wire, so nothing is the correct color anymore and it's impossible to trace. The switch is a 1964 I believe. Thanks!
muddpile is offline   Reply With Quote
Old 05-27-2008, 11:58 PM   #2
Ham-er
Re: stock headlight switch wiring diagram?
try this site
http://64moneypit.pages.web.com/id64.html
Ham-er is offline   Reply With Quote
Old 05-28-2008, 12:22 AM   #3
joe231
joe231's Avatar
linky
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 05-31-2008, 08:23 PM   #4
muddpile
muddpile's Avatar
Got it hooked up and working. Thanks guys!
Old 06-20-2009, 01:33 AM   #5
jibbyjammin
can you please tell me how you fixed the wiring? I am currently in the same position, any help would be greatly appreciated.
jibbyjammin is offline   Reply With Quote
Old 06-20-2009, 08:13 PM   #6
muddpile
muddpile's Avatar
Oh boy, this was over a year ago so I'm a little foggy, but I'm sure I used one of those two links and got it done quick as could be.
Old 06-21-2009, 01:26 AM   #7
jibbyjammin
I appreciate you trying to remeber, i looked pretty good all threw both links and did not find it. Well if you should think of something else any help would be greatly appreciated, it is drivin me nuts. Thanks
