06-04-2008, 04:05 PM | #126 | |
Re: kp components weld in step notch
- Clint - |
06-09-2008, 10:45 AM | #127 |
Thanks Clint.. I will be calling you fairly soon.. Just need to save up some cash and fix a few issues on my frame.. Question.. I have the stock crossmember where the trailing arms connect too. With this notch nad air ride set up will I have to replace that.. I assume at full dump my drive shaft is going to hit the top of it where it goes through the corssmember..I see CCP sells one that is made for our trucks but can you just modify this one or will the stock be okay. Just need to know before i bolt my cab back on.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074 Toys: 2014 Dodge Ram 1967 SHORTBED |
06-09-2008, 12:07 PM | #128 | |
06-13-2008, 11:11 PM | #129 | |
06-16-2008, 11:01 AM | #130 |
The frame rails are the same between step side, and fleetside.
- Clint - |
06-16-2008, 09:20 PM | #131 |
I think he's more concerned about the bedsides.
06-16-2008, 10:39 PM | #132 |
yea or the 4 link being where the step goes or the cantilever/bag setup hanging out from under the bed to interfere with the rear fenders.
OH well there is other options for us step guys. Last edited by original_balzer; 06-16-2008 at 10:40 PM. |
02-11-2009, 01:10 AM | #133 |
So is the rear kit available for the 72 yet? havent seen it on the website
02-11-2009, 07:21 PM | #134 |
I/m also interested in the KP notch, but I/m using CPP round tube trailing arms and c-notch will I have to relocate my bags and shock mounts to make this notch work? My bags are in stock location as well with shocks on a 72.
02-11-2009, 09:28 PM | #135 | |
VERY NICE!!
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
02-11-2009, 09:33 PM | #136 |
A guy with a truck
To take advantage of the height of the notch, you will want to move the bags. They will be the limiting factor in how low you can go, followed closely by trailing arm/frame interference. Stock style shock mounting becomes unusable not only because you lose your upper mounts, but the angles are very extreme when dropped that low.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-12-2009, 12:14 AM | #137 | |
Also..... The stock lower shock mount configuration could prob still be used w/a new upper mount as long as it was set-up w/the correct travel dimensions vs. the bag height (extended & compressed).
02-12-2009, 06:58 PM | #138 |
Our rear system is currently in production and is expected to be available for shipping around March 1st. We're also in the process of completing our bolt-on step notch kit for the 63-72 trucks as well. We already have one for the 73-87 trucks. Anyone interested can contact we via email and I can keep you posted on progress of all our early C10 developments.
cpetree@cachassisworks.com Thanks
- Clint - |
02-14-2009, 12:28 PM | #139 |
Can anybody post some pics of a truck using the kp notch and bags in OEM location?
02-14-2009, 01:24 PM | #140 | |
http://www.67-72chevytrucks.com/vboa...hlight=filmguy
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-14-2009 at 01:25 PM. |
02-14-2009, 11:42 PM | #141 |
SOLD
Location: Poorest state in America(Breaux Bridge,Louisiana)
that looks simple and clean.........nice
1966 CHEVY FLEETSIDE SOLD 11-29-9 TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2 |
04-08-2009, 09:53 PM | #142 |
what kind oftrailing arms are those in the pictures above?
04-08-2009, 09:55 PM | #143 |
PROJECT 7DEUCE
Those look to be the cpp trailing arms.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-09-2009, 12:03 AM | #144 |
Correct; they're CPP's.
04-21-2009, 11:24 PM | #145 |
okay cool cool is i did that same thing with the cpp's trailing arms how low would the truck sit with 22's?
04-21-2009, 11:51 PM | #146 |
Depends on the diameter. Most likely it won't sit any lower than that regardless of whether the tire has a shorter sidewall (or same size) because the 22" wheel will grow 1" on top & bottom of the axle C/L.
04-21-2009, 11:53 PM | #147 |
alright cool i appreciate your knowledge.
well if i put like 2 inch lowering blocks on those cpp trailingarms wouldnt that make up for the 2 inch bigger wheel? |
04-21-2009, 11:59 PM | #148 |
The truck in the pic has lowering blocks w/the CPP arms. That's why it's @ the limit.
04-22-2009, 12:01 AM | #149 |
oh i gotcha! well what is your opinion on the canti set-up?
04-22-2009, 12:17 AM | #150 |
The KP canti-lever will definitely allow for 'laying out'.
From what I understand though (from them), the set-up is not recommended for big power combo's. So.... a stockish small-block that's just a driver, sure. A bad-a torque monster or if you still want to use it like a truck (tow/heavy load) look for something else. This was back when they first put up the pics so they might have made changes. I would call KP & ask them first hand for the most accurate info.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-22-2009 at 12:19 AM. |
