What kind of Damage...
Can i be looking at driving my 87 sierra 1/2 Ton 457 miles with a rear main seal leaking on it?
Bill |
Re: What kind of Damage...
Keep the oil pan full and you'll be fine. Usually it makes a big mess but check it every so many miles and add oil to it.
My Truck's not leaking its marking its territory! |
Thank you for the help. I am hoping to get my truck home this weekend from Indiana.
Where in Indiana? I'm in Franklin (25miles south of Indy). Orginally from Parkville MO
My Truck's not leaking its marking its territory! Last edited by 87Bob; 08-20-2009 at 03:47 PM. |
up near kokomo north of indy. I was going to have someone tow it out here but the cheapest (which is cheap dont get me wrong) is 400 bucks. However if i drive it even at 10 mpg (gets better then that) it will only cost me 180 including the second car worth of Gas driving out to pick it up.
Yeah...i will probably buy a case and check the level every fill up...every 2 hours..(7-8 hour trip) what do you think?
![]() Join Date: Jul 2009
Go for it! And have your "chase" vehicle follow you to watch for a sudden indication of excess oil loss. If his windshield is getting "oiled" it might be time to reconsider your trip
Well going off a buddy...he said pretty good size while sitting still...but I had the rear seal on the tranny replaced and then had it serviced...they found nothing leaking..but..not sure..the friend is pretty good mechanically..he said he knows the difference between ATF and oil...but the oil changer didnt see a leak..i am just not taking chances.
Lucus oil treatment might slow it down a bit
if it was me i would get thicker oil for the drive home.
more good ideas...thanks guys..i will have pictures up when I get it here
Well it is official as long as nothing weird happens to chuck (my truck) then he will be home Sunday in Missouri. Should be a fun road trip. Anyone know at what speed a 350 gets the most optimal gas mileage.
#15 |
This trip sounds like a cheap way to rust proof the bottom of your truck.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#16 |
since its its fuel injected i would drive 65-70. i would guess it has a 3.08 gear so it will cruise just fine on the hwy at high speeds.
#17 |
If you check it after 50, 100, and 150 miles you'll have a good idea how much your losing for a given distance. Then you can be sure to stop before you lose to much. Be sure to check your oil pressure gage (or the idiot light) when you start up and that will give you a safety check backup.
#18 |
and don't forget to call up the indiana dot and ask where to send the bill for re oiling the roads for them
![]() if its going through a lot I'd look into finding some of that cheep reprocessed oil that you can buy in the 2 & 5 gal. jugs
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
#19 |
![]() ![]() Join Date: Dec 1999
Did you get it home?
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
#21 |
Yes sirs we got home last night...about 1 am. I had an interesting weekend..nothing dealing with the truck...just other stuff happening over the weekend. I hope to have some pictures up today!
#22 |
Glad you made it home ok!
#24 |
How much oil did you consume? What was your fuel mileage?
#25 |
well believe it or not i did not consume any oil or VERY little. I checked it often (at least 5 times in the 8 hour trip) and nothing was missing. So not sure what they were talking about.
Mileage wise...well that is hard to tell...I found that my gas gauge is off seeing that it is a 16 gallon tank and i filled up at 1/4 left and only put 9 gallon in it. If i had to take a guess...i would guess between 15-17 mpg. |
