#26 | |
![]() Join Date: May 2009
Re: The old "best" starter to use topic....
If it looks like this its a 92-96 corvette starter, requires a small flywheel. Very good starter.
1970 Chevy LWB A/C P/S Tilt 350 Edelbrock heads 700R4 SO-CAL power windows & vintage Fenton aluminum slots 1985 Chevy Suburban 3/4 Ton with a 2004 5.3/4L60E 1985 Chevy Silverado 10 custom ext. cab 305/TH350 1997 Dodge Ram 3500 ext. cab Cummins 5spd Last edited by clinebarger; 11-02-2009 at 11:14 PM. |
#27 |
loaded up & truckin'
![]() Join Date: Aug 2004
68 C10 CST, 454 TBI, a/c, buckets, disc brake 9" 93 K10 Short Step, 350, 5spd 04 Passat TDI 09 Corolla S |
#28 |
I have the red skip white mini starter and it works great and their customer service is awesome.
#29 |
Go Cowboys!
#30 | |
CST on a WT budget
![]() Join Date: May 2005
![]() They are smaller than other mini starters, and sounds like a new truck when you fire it up.
68 C10 50th anniv. 350, Performer RPM heads, Lunati 272/282 solid ~10:1, Quadrajet, MSD digital e-curve distributor Super T-10 4-speed 3:73 posi 14.2 @ 93.5 with old cam. |
#31 |
Professional Grade
![]() Join Date: Aug 2008
#32 | |
Professional Grade
A heat sink (or heatsink) is an environment or object that absorbs and dissipates heat from another object using thermal contact (either direct or radiant). Heat sinks are used in a wide range of applications wherever efficient heat dissipation is required; major examples include refrigeration, heat engines, cooling electronic devices and lasers. (A Heat SINK would actually help in this instance). |
#33 |
Professional Grade
Mounting the solenoid usually does fix this. I believe all that s needed is a Ford solenoid
. I run the two wires that normally go to the S terminal on the stock starter to the s term. on the remote sol. and I run a jumper wire or a bus bar from the s term on the starter to the large post for the batt. cable. The I just run the cable to the remote sol. and another cable to the starter from the remote sol. So it is basically just splitting the pos. cable.
#34 |
Go Cowboys!
red "skip white" starter arrived today, dropped it in and it is awesome so far!!
| Thread Tools | |
| Display Modes | |
