Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 99+ Chevy and GMC Message Board
Old 11-03-2009, 12:56 PM   #26
fxdxharley
fxdxharley's Avatar
Re: 2000 6.0L runs rough and stumbles
Originally Posted by clinebarger View Post
Im guessing no check engine light? Like posted before the MAF can go bad and not set a light. EGR valve stuck part way open, Vacuum leaks, TPS sensor with a dead spot. If you do have bosch plugs throw them away there junk. Ive always ran NGK V-power plugs there cheap and a good plug never had a problem.
have you checked fuel pressure? Key on engine off 55-62 PSI.
Nope no check light. I've unpluged both the maf and tps and ran it to see if there was a difference none noticed. i do have the bosh platums. How can i check to see if the egr valve is stuck? Never check feul pressure. I hope its good, the pump is only 2 yrs old.
2000 chevy 2500 4x4 3dr swb
2000 harley fxdx
2007 honda crf 450x - street legal
2003 honda crf 50- 88cc kit
2005 kawi klx 110 factory moster energy kawi pit bike - sons bike
fxdxharley is offline   Reply With Quote
Old 11-03-2009, 02:30 PM   #27
truckdude239
truckdude239's Avatar
bad fuel pressure regulator I've seen it many time on these
David fuller
1971 Chevy c-10 with a rebuilt 305
1987 Ford F-150 302 v8 auto -
1993 ford aerostar dads car
RIP ESLL
truckdude239 is online now   Reply With Quote
Old 11-05-2009, 06:09 AM   #28
fxdxharley
fxdxharley's Avatar
Nope, changed that too when it had a hard starting issue.
2000 harley fxdx
Old 11-05-2009, 12:28 PM   #29
basemodel67
Nor-Cal Joggernuts
Where is is the regulator on these things? Maybe I should change mine. BTW, when my truck broke a valvespring, the check engine light never came on when I thought for sure it should...
Just 'cause I don't know what it is, doesn't mean I'm lying.
basemodel67 is offline   Reply With Quote
Old 11-05-2009, 12:55 PM   #30
Shon
If you have a feed and return line on the fuel rail then the little round thing that has a vac line attached to it is the regulator, if you only have 1 line to the rails then it is in the tank, part of the fuel pump assembly.
Shon is offline   Reply With Quote
Old 11-07-2009, 06:06 AM   #31
fxdxharley
fxdxharley's Avatar
that is correct. it is on the drivers side fuel rail. check and see if it is good is by running the truck or cycle the fuel pump with the key, shut it off then up plug the vac line from it. If gas comes out of the port then it is no good. A nother sure way to tell is if your truck starts hard ie cranks over for a little bit before firing up. the pressure reg is a dealer only item and is just over a $100 bucks.
a broken valve sring wouldnt trip the check light.
2000 harley fxdx
Old 11-08-2009, 11:03 AM   #32
truckdude239
i did not think of the valve spring but they are common on these style motors
David fuller
RIP ESLL
Design By: Scott Stubblefield Ported to vB by: Miner
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
