Old 11-06-2009, 10:58 PM   #1
chevjayfsd
My Smallest Truck
chevjayfsd's Avatar
Complete My Parts List Please
I'm new to the bag world. I need some of ya'lls help in finishing up my parts list. I have searched and searched, but can't seem to find all of the little parts and pieces I'll need. Pictured below is what I have so far (all from suicidedoors.com) I am also going to be purchasing my switchbox from eBay (7 switch EAI box.)
Any help would be greatly appreciated!
72 Chevy SWB
350/TH350
5.5"/4" static drop
3 year frame off build
Future Plans:
18"/20" wheels
Bagged
chevjayfsd is offline   Reply With Quote
Old 11-06-2009, 11:56 PM   #2
leftcoast66
leftcoast66's Avatar
Re: Complete My Parts List Please
You'll need all of the fittings for the air lines, but you may be able to get those locally. Also, not sure how your planning on mounting the rear setup, but that's not on the list. A watertrap wouldn't hurt, I never run one, but next setup I most likely will. Also a pressure switch will be needed, and of course a tank. I know i'm probably missing somethings, but that should get a start.
leftcoast66 is offline   Reply With Quote
Old 11-07-2009, 12:11 AM   #3
chevjayfsd
My Smallest Truck
chevjayfsd's Avatar
As far as the rear setup goes, I was just going to replace the coil with the bag. No notch, no hacking. I don't wanna lay frame by any means, but wheni get my 18/20" combo, I wanna be able to dump it when the truck is sitting.
72 Chevy SWB
350/TH350
5.5"/4" static drop
Future Plans:
18"/20" wheels
Bagged
Old 11-07-2009, 12:19 AM   #4
edflores
you need a tank.
and i would not use the eai box. they are crappy at best.
and i would get regular valves, and buy those from waylayd cause they are cheaper.
edflores is offline   Reply With Quote
Old 11-07-2009, 12:25 AM   #5
leftcoast66
Very cool, be sure to C notch it, I ran the same all through highschool w/ bags replacing the coils. Definitely just put a C in so you have a little bit of travel while driving.
Old 11-07-2009, 02:06 AM   #6
chevjayfsd
My Smallest Truck
chevjayfsd's Avatar
Originally Posted by edflores View Post
you need a tank.
Why would I get regular valves instead of the ones I listed? What would be the pros and cons of running what's in my shopping cart?
72 Chevy SWB
350/TH350
5.5"/4" static drop
Future Plans:
18"/20" wheels
Bagged
Old 11-07-2009, 02:56 AM   #7
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Stick with the valves you have listed.
Some people buy their toys, some people build them.
91 Suburban R1500
87 Silverado Lifted 4x4
78 C10 Chopped & Dropped Build Thread
smashingchuck is offline   Reply With Quote
Old 11-07-2009, 09:32 AM   #8
Shane
Registered Offender
Shane's Avatar
The EAI box and the valves you have listed are fine. I would double up on the compressor and go with two 3 gallon tanks.
Keep On Truckin'
Shane
ΙΧΘΥΣ
Shane is offline   Reply With Quote
Old 11-07-2009, 11:14 AM   #9
kev2809
kev2809's Avatar
i have the eai box from suicide doors, the 5 switch one. havent installed it yet but i trust what sd sells...get a 5 gallon tank, get the sqaure d pressure switch since its adjustable and only like 5 bucks more than the non adjustable ones, and of course fittings. you may want check valves down the road also to prevent air leaking back into the tank (you would need 4 of those), and a water/oil trap. oh, and i would notch it if i were you, get a few more inches at dump plus it will ride better with one. i think thats it...
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 11-07-2009, 12:20 PM   #10
edflores
The eai boxes are crap. The 3 i've had had sticky switches within a month. They are cheap for a reason
Everyone with avs boxes still use them with no problems and they have a warranty in case anything should come up.
And why would he get a pressure switch that would void his warranty? Viair includes the correct pressure switch and relay with their compressors.
The manifold valves are fine, but i would save money and buy the regular valves. price is the only factor there. Both are quality parts. If spending the money though, i would just step up to the accuair manifold
Old 11-07-2009, 05:16 PM   #11
kev2809
kev2809's Avatar
i did not know this since i dont have or have bought a viair compressor from suicide doors. soo, now knowing this i would just go with the switch they recommend. if i had known that, clearly i would not have suggested it
-_--_--_ _________
Design By: Scott Stubblefield Ported to vB by: Miner
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
