11-13-2009, 12:02 AM | #1 |
Lets see your gauge panel!
Here is my gauge panel that I made. I kept the original speedometer and used a piece of sheet metal to cover what I didnt want. Then I went had a sticker made for the speedo numbers. I also use arcrylic for the lens that I bought at home depot.
11-13-2009, 08:19 PM | #2 |
Re: Lets see your gauge panel!
heres a couple
JUST ASK |
11-14-2009, 09:57 AM | #3 |
11-14-2009, 02:16 PM | #4 |
Keepin it old school
11-14-2009, 04:21 PM | #5 |
Member of the longbed union.
I dont have pics of mine, but it will be made just like Bazookas
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
11-14-2009, 04:37 PM | #6 |
Has anyone come up with a good way to fill or hide the holes in the frame for the switches and ignition, etc... that aren't being used any more? I would like to do this and maintain the horizontal line detail if possible. I am going to set mine up like wildstangracing's dash
11-14-2009, 06:20 PM | #7 |
I need to know the same thing dlisabeth. I thought about filling it with kittyhair.
11-14-2009, 06:30 PM | #8 | |
Resistance is Futile
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
11-14-2009, 07:22 PM | #9 |
Here's one for a GMC I painted the back ground satin black and it looks a little better but I'm still not satisfied, I found some engine turned alunimun sheet stock at www.speedwaymotors.com Part # 911-39520-24 6x24" .063 thick so it shouldn't be to hard ti cut out in the stock configuration as back ground. The stock bezel on these are plastic, does any one know of any where that you could get the plastic chrome plated again there must be somebody doing this somewhere don't you think? I do like the stock configuration with the exception of the idiot lights I may get some smaller jewel faceted lights instead and put in there place. Anybody have anymore ideas for ?---Vernski
11-14-2009, 07:36 PM | #10 |
before
after
Greg Smith a.k.a. "The Highlander" 1966 C20 Custom Camper, 2017 Chevy Silverado 1500 Highlander's Project Pics Highlander's web site: www.6066ChevyTrucks.com |
11-14-2009, 09:24 PM | #11 |
11-14-2009, 09:47 PM | #12 |
That looks good.
Thanks for the Idea Protrash
11-14-2009, 10:02 PM | #13 |
Here be mine, the stock look before and the custom made insert with analog dial after (I do not like idiot lights) I simply took the natural layout and replace the lights with gauges. The tach and Clock are GMC OEM pieces and work great.
http://s1299.photobucket.com/user/jb...23904108567829 |
11-15-2009, 01:05 AM | #14 |
QUESTION:
Does the GMC gauge cluster fit into a chevy? I like how the GMC has the round individual gauges. |
11-15-2009, 01:25 AM | #15 |
60-66 Nut
No they are specific to the GMC's
You could have the same look with aftermarket gauges......
11-15-2009, 01:44 AM | #16 |
Dash shaped different or????
11-15-2009, 01:54 AM | #17 |
Here are a few of a cluster I have in my '66 Chevy C20 Custom Camper. It is heading to a fellow member this week.
11-15-2009, 01:57 AM | #18 |
What does it take to swap that cluster in where idiot lights were?
11-15-2009, 02:03 AM | #19 |
In the 4-5-6 Chevy trucks, the only part that is the same on the gauge cluster and warner light cluster, is the bezel, so it is better to find a gauge cluster, instead of trying to modify a warning light cluster.
11-15-2009, 02:06 AM | #20 |
I guess I should re-phrase the question . . .... If I have a 'warning-light cluster' & wish to upgrade to a factory style 'gauge cluster', what do I need to do?
11-16-2009, 01:18 AM | #21 |
60-66 Nut
Basically yes. The GMC gauge panel is longer and I believe narrower that a 64-5-6 Chevy gauge panel. Plus the GMC's still had the switches in the dash below the gauge panel, similar to the '60-'63 Chevy's
In addition to the gauge panel, you will need the wire harness that connects the panel to the connector that is attached to the pedal bracket under the dash. The oil pressure is a mechanical gauge, so you will need to run a line for that. And of course you will need the correct sending unit for the H2O temp. I believe that is all that is needed.
11-16-2009, 02:18 AM | #22 |
Wide Eyed User
does this count ? lol
more current... like last friday..lol
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ) Pics: http://67-72chevytrucks.com/vboard/s...d.php?t=393441 Last edited by DaddyMack; 11-16-2009 at 01:19 PM. |
11-16-2009, 10:37 AM | #23 |
///Relaxed Atmosphere
here are my mooneye gauges im putting in my 64
72 Suburban 64 Chevy short fleet 04 Chevy Colorado Sport Reg Cab 2012 Chevy Avalanche 2003 Chevy S10 Blazer Xtreme http://www.hubgarage.com/mygarage/RA_Jeff 64 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=295915 |
11-16-2009, 05:50 PM | #24 | |
Junior Member
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! |
02-15-2016, 02:23 PM | #25 |
here b my gauges
