Old 11-29-2009, 01:53 PM   #1
Cw72gmc
~Craig~
Some Fuel Pump Help Asap? Thanks!
Ok so I started my truck yesterday....saw what i thought was coolant dripping...realized it was fuel coming from the pump. By the time i got there it was so soaked i couldnt tell if it was a line, or the gasket that meets the motor.
I'm hoping its just a line.
However, If i need to replace it can it be a pain in the @ss? Not that I dont like getting my hands dirty...I'm just juvenile diabetic and have been having bad low blood sugars all night....dont feel to well. But i need the truck today! Any help or advice is greatly appreciated!
Cw72gmc is offline   Reply With Quote
Old 11-29-2009, 02:17 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Some Fuel Pump Help Asap? Thanks!
its not too bad hardest part is lining the rod up in the pump
John
1999 Toyota Tacoma 4x4
Old 11-29-2009, 03:12 PM   #3
cdowns
cdowns's Avatar
ithe gasket between the block and the pump is not for sealing gas//if gas is leaking from that area chances are the pump is bad and needs replacement due to ruptured diaphram in the pump,if that is the case you need to worry about your oil being contaminated by the leaking gas
drink a regular cokethat's what i do i'm an old diabetic
Old 11-29-2009, 03:18 PM   #4
tim21391
tim21391's Avatar
a new fuel pump is cheap to its like 20-25 bucks.. and then theres a plug u can take out after u get the fuel pump out and then you can ram a screw driver in the hole where the plug went so it can hold the rod from coming out.. then shove in your fuel pump then tighten the plug then tighten fuel pump.. it took me less then 30 minutes to swap mine out.. i did it on my lunch break one day... u just need to shove a bolt in your lines and clamp the line on the bolt otherwise you will lose all your gas.. i lost all mine that way because i just let it drip all in a pan
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 11-29-2009, 04:15 PM   #5
463
463's Avatar
or i use a gob of sticky grease on the push rod end that goes into the block to hold the rod up there for the ten seconds it takes to aline the pump and bolt it on.
Trueman
463 is offline   Reply With Quote
Old 11-29-2009, 08:40 PM   #6
Cw72gmc
~Craig~
Hey guys, I broke down and changed it. It wasn't bad at all. Kinda feel like a tard worrying about the difficulty of it!
Thank you all for your quick and generous responses!
Old 12-03-2009, 03:53 PM   #7
tim21391
tim21391's Avatar
no problem not as bad as my first fuel pump problem.. filled up when gas was 3.50 a gallon.. and next morning my full tank was all over my driveway and then on top of that i didnt know about the rod and so i spent hours and hours wondering howcome i have a big gap... haha
Old 12-03-2009, 04:03 PM   #8
ges55
BLACK SATIN
ges55's Avatar
I read somewhere to use a hacksaw blade to hold the rod up. That's what I've done the last couple of times.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new
67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering
85 C10 Silverado- 305ci
ges55 is offline   Reply With Quote
Old 12-03-2009, 05:43 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the trick of removing a bolt and installing a longer bolt to hold the pushrod (or a screwdriver I guess) is onnly on small blocks.
Old 12-03-2009, 06:28 PM   #10
69GMCLonghorn
69GMCLonghorn's Avatar
As for that Diabetes thing, I'm a Type 1 and have an insulin pump with a glucose sensor. Man, let me tell you it is night and day difference from the old shots and blood sugar testing... It can help those low blood sugars more than you know...
69GMCLonghorn is offline   Reply With Quote
Old 12-03-2009, 06:41 PM   #11
fdbdw
fdbdw's Avatar
When I did mine I put the #1 at TDC that clears the lobe from the rod and makes it real easy to grease and slide it way up in there so you dont have to fight the pump lever while bolting it up
fdbdw is offline   Reply With Quote
Old 12-03-2009, 08:43 PM   #12
Cw72gmc
~Craig~
I lucked out and my motor was darn close to tdc. It went in like nothin!
Old 12-03-2009, 08:55 PM   #13
big mike71
big mike71's Avatar
You should change your oil just in case. because if you got gas in it, it can cause big problems.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 12-04-2009, 12:57 AM   #14
Cw72gmc
~Craig~
I did because I was under the truck anyway...although I found the leak was coming from the can of the fuel pump...from the seep hole.
