Old 11-30-2009, 01:07 PM   #1
Hair
Shift Indicator Light
Redone my steering column. Auto, 2 speed
I found a little fiberoptic cable in there that ran up to the shift indicator. One end plugs into a light socket and the other end plugs up into the indicator.
I cleaned everything good and put in a new bulb and expected to see a big bright lighted up indicator, but it did not happen. It's just a tiny little light that really doesn't help much. Is that normal?
Is that just as good as it works? Maybe it will show up better in the total dark, but setting in the shop, I wonder why they even bothered.
Hair is offline   Reply With Quote
Old 11-30-2009, 01:49 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Shift Indicator Light
LMAO I did the same thing ..subscribed to see what others say...kinda like my heater control light....
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 11-30-2009, 03:18 PM   #3
chris71
chris71's Avatar
You may want to pull the fiber optic cable out and inspect, if it is frayed at all (like mine was when I swaped columns) it wont let as much light to the indicator. there is also a trick where you can put in a different bulb in your gauge cluster to make it brighter, but I cant remember the type of bulb. a bunch of guys do this just to make their dash lights brighter. hopefully someone will chime in with this bulb info.
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 11-30-2009, 04:54 PM   #4
red71c10
The Red Menace
red71c10's Avatar
I got mine working a while back and it's not spectacular, but it get the job done. I'm not sure I would want it much brighter, it would probably be distracting.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 11-30-2009, 06:05 PM   #5
rambler
MOVE OVER
rambler's Avatar
you mean there is actually a shift indicator light and a heater control light?
LOL....
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 11-30-2009, 06:09 PM   #6
Hottrucks
Hottrucks's Avatar
yea why is it that the light for the heater A/C is on the other side of the controls oposite side of the fan which is what I wanna see ??...or is there supose o be a light on that side too??
Old 12-02-2009, 11:55 PM   #7
425HP409
425hp409
425HP409's Avatar
The end of the fiber optic cable needs to have a clean cut end to transmit the light properly. Take a razor blade and trim the ends smooth and it will work better.
Charles
68 SWB, Dad bought new
63 Impala Sport Sedan
64 Impala SS, 409 425HP
64 Bel Air Wagon
57 Bel Air w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
80 Olds 98, Mom's old car
425HP409 is offline   Reply With Quote
Old 12-03-2009, 10:49 AM   #8
Hair
LOL....
My truck is a non A/C truck, I don't think it has a heater light. I took all the heater out too and re did all of it with new ducts, rubber, and everything and my control box "aint got no" light bulb no where. Do all heaters have lights?? If so, where is the buld supposed to be??
Old 12-03-2009, 12:03 PM   #9
red71c10
The Red Menace
red71c10's Avatar
The light is in the controls next to the levers. It lights up the words Def, Heat, Fan etc...
Old 12-03-2009, 03:01 PM   #10
Hair
Then mine did not come with lighted heater controls then.
Old 12-03-2009, 04:51 PM   #11
red71c10
The Red Menace
red71c10's Avatar
There's no socket on the back of the controls? It looks like a square pot metal box with a round hole that the socket and bulb plug into.
Old 12-03-2009, 05:40 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
all heater controls, a/c or non a/c had lights.
Non A/C had a single bulb as described above, A/C trucks had 2 bulbs on the control panel, one left, and one right.
Old 12-03-2009, 07:58 PM   #13
Hottrucks
Hottrucks's Avatar
thanx Longhorn Man I thought I had something special with just one light on my A/C controls...now I have to spend more time on my back looking under the dash and find a second light socket
Old 12-03-2009, 10:57 PM   #14
Hair
Okay, found it. It's a litle bitty bulb, doesn't look as big as even the ones in the dash cluster. I had not plugged it back in. Bulb is bad. Maybe they make a little LED bulb that will fit?... may be brighter.
Old 12-04-2009, 12:47 AM   #15
highperf4x4
I have lights on both sides. However, mine looks like it has 2 bulbs on the passenger side and only 1 on the drivers side. I'm gonna have to look underneath and verify that though. It's probably just a reflection. I know the passenger side is definitely brighter than the drivers side however, sometimes I have to bump the bottom of the dash to get the pass side to come on
highperf4x4 is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
