Old 11-22-2009, 04:14 PM   #1
cjthor
Problems with my eaton rear disc brake swap :(
OOOOOkay! So I purchased a set of DIY4x brackets to swap rear disc brakes on my 70 K20. I pulled the drums/hubs off and seperated them....went to put the rotor from a 73 4x4 on the hub and they dont fit! The mating surfaces do not touch. Do I need rotors from a 2wd or something? Any help is appreciated!
JP
70 K20
74 CJ5
cjthor is offline   Reply With Quote
Old 12-09-2009, 01:31 PM   #2
BTCHN 1963
BTCHN 1963's Avatar
Re: Problems with my eaton rear disc brake swap :(
Are you using 3/4 4x4 front rotors?
BTCHN 1963 is offline   Reply With Quote
Old 12-09-2009, 04:13 PM   #3
ghettoluxury
ghettoluxury's Avatar
the studs have to be removed and the rotor placed on the back side of the hub then press the studs through
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 12-09-2009, 04:16 PM   #4
cjthor
exactly...It was late when I was trying this and put the rotor on the wrong side....dork is me!
JP
70 K20
74 CJ5
