12-09-2009, 08:36 PM | #1 |
driveshaft hook up....help
Hey all,
need a lil help with my 1983 k30 4x4 350 when i got the truck the driveshaft was in the bed and the guy said it had a bad u-joint. Well I think it was a lie, dude told me u-joint was good shape. I need to know what I am missing. I have the driveshaft but the shifter inside the truck just moves freely, do I hookup the driveshaft and it will fix that? I am pondering my mind and reading online but can't find what I am looking for. Any help would be great. |
12-09-2009, 08:45 PM | #2 |
Re: driveshaft hook up....help
and I have one more quick question i am sure yall could answer.
Is it safe to use a shackle on the front leafs? |
12-09-2009, 09:24 PM | #3 |
20' Daredevil (Ret)
If you are talking about putting shackles up front -- NO
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 12-09-2009 at 09:27 PM. |
12-09-2009, 09:29 PM | #4 |
10 4.
Thank you on clearing that up. |
12-09-2009, 09:34 PM | #5 |
and i know im killing yall with all these other little questions, but one more. I wanted to body swap my 4 door k30 single axle. Think of anything besides the identical body that will mount to the frame?
12-09-2009, 09:37 PM | #6 |
Chevys Kick A$$
Wait to your transfer case shifter just moves freely? Either your transfer case shifter is not hooked or something between the to things is broken! X2 no shackles up front!!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
12-09-2009, 10:59 PM | #7 |
10 4.
Yeah like the shifter was rigged backwards with a bungee chord when i let it go it was just moving around. |
12-09-2009, 11:01 PM | #8 |
whats wrong with the 4 door?
1949 Five Window, 1973 Step Side, 2000 Z71 |
12-09-2009, 11:07 PM | #9 |
all in all.
Needs some new seals nothing too major. except for the fact its got rust, and the 4x4 needs to be hooked up/fixed? Idk I want to fix it. |
12-09-2009, 11:12 PM | #10 |
I wouldnt recomend it these crew cabs are gettin harder to find
12-09-2009, 11:29 PM | #11 |
i ment the 4x4.
good news i can feel it drop into the gear however when i bring it from 4wd hi to 2wd it clicks and stuff. |
12-10-2009, 12:19 AM | #12 |
and any idea where I can get a body lift for my k30? for a good price?
12-10-2009, 12:46 AM | #13 |
I read where this guy did the b52 kit and used shackles on the front leafs just in the rear position.....
12-10-2009, 06:28 AM | #14 |
Sb 400 club
yeah these trucks came factory with shackles on the rea of the front springs. Alot of guys upgrade them for streanght. Offroad design makes a kit called HD shackles which are a 1/2 long and much thicker then stock..... However a shackle "lift" in the frint is not the best iddea. The b52 kit allows you to run your stock 52 inch rear springs in the front in place of your 3 leaf factory springs. This gains about 4 inch lift and allows for better flex then a lift spring. Your truck has 56 inch long rear springs if i remember right biut i beleave the kit has multiple holes to allow for the use of 56's
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out Last edited by 84 400; 12-10-2009 at 06:52 AM. |
