#201 |
Re: my radical 60 build
Looks Cool
#202 | |
1961 crewcab
I did not need to lengthen the roof, however you would have to either lengthen the top of the door, or as I did change the back edge of the door to get it all to line up. the front post was just straight down and everything lined up. I did remove a portion of the inner garnish moulding to line things up and access the inner roof brace inside the post for welding.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#203 | |
i decided im not chopping it now, and also not shaving drip rails. thanks for the advice tho. ..maybe on i will chop the next one haha ![]()
1960 Chevy Short Wide Truck(being restored) 1962 Pontiac Parisienne Bagged 1996 Chevy Caprice 9c1 ![]() |
#204 |
if you work the spotwelds loose and step the inner and outer part of the pilar you have a lot more reference to check if its on straight a lot more room to put clamps on and keep it in place and a lot less chance it will flex and crack the paint over the butweld at a later date it will be a lot of work to work them loose though
never mind i was just looking through the pics again that would only complicate things more
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 01-18-2010 at 01:56 PM. |
#205 | |
#206 |
from wat i read we both have the same idea
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#207 |
How in the HECK have I been missing this post???????????? This truck is awesome! My dream has always been to build a 60s style kustom, and as soon as my 65 is finished for my wife to drive, thats exactly what I am doing!! I love all the step by step photos. helps alot to see how this is done, and how you are measuring for cuts. this is the stuff none of the magazines show,,,the inside work. anyways, enough of my flapping! Good work and keep us posted PLEASE!!!!!!!!
#208 |
TexasBowhunter
Mad skillz, my friend!
Build in progress for son's first truck. |
#209 |
![]() Join Date: Apr 2009
that is a awesome truck/car ok TRUCK
#210 |
Man That is some Hard Core metal work. I thought that I had my work cut out for me on mine only to see this, what great work and a cool ride
Can't wait to see the finished product, keep up the great work |
#211 | ||
1961 crewcab
It was cold this winter, and I was lazy!, so nothing new to report as of now.. my to do list: grind welds on roof and paint them so they don't rust. get windshield done install headers install converter lock-up for the 2004r trans start on blending the front fenders to the doors. + lots of other welding and grinding ![]() we'll see how long it takes me now that spring is here.
#212 |
Resistance is Futile
Hurry up!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#213 |
1961 crewcab
hey!
a tiny bit of progress.... getting the new windshield shape has been tough... I have heard all sorts of ideas from making a fiberglass buck for a windshield to framing the shape out with aluminum and wire... the biggest issue was that the glass sits a 1/4 inch away from the pinchweld, and a 1/4 inch up from it, when it is in the gasket. If I shaped the glass to the pinchweld, it would end up being too big..... so what I did was use an old windshield gasket, it sat in the bottom fine , but I had to screw it into the roof at the top to keep it in place. I cut away the glass retaining portion of the gasket on the outside, on the corners and top, I left the center of the bottom intact. then I used a flat piece of cardboard for the center leaving the corners off. after I got that cut to fit, I started making the corners with lots of tape and many triangle shaped pieces of poster board. on the photos of the windshield you can see the pattern where the glass needs to be cut: a little off the top, and some off the lower corners and back. now I have my pattern, next is how to cut the glass... a bodyshop friend of mine has a diamond tipped rotary blade that he has not tried out yet, and there is the sandblast method... I am not sure which method I will try yet, I only have 2 windshields, the blade would be fast, but the sandblast method is about 99% safe, it just takes something like 6-8 hours...
#214 |
1961 crewcab
I also spent some time grinding welds on the roof, and put some primer on it so they wont rust...
#215 |
1961 crewcab
shop has been a little tight this winter!
the elcamino has been back burnered since I started the truck project, then the storage on the convert went away, so it came in for a floor, brakes and an engine... then winter hit, so the truck had to come in , because I had not finished grinding / painting the welds, and no glass yet.... then my wifes 63 project is in the driveway blocking all three of these in.... ![]() ![]() ![]()
#216 |
One day...
Cool man looking good!! I have heard some horror stories about guys going through many windshields trying to cut them down but then others that have just the single time. I would hit up a couple glass shops and see if they could cut it for you, just a thought though.
#217 |
1 thing at a time is progress.
Nice progress Jon, I wish I had some advice about the glass, but I'm clueless.
Alan
Philippians 2:14-16 |
#218 |
With laminate glass, I believe it has to be cut twice. Once on the outside and then repeated for inside. Then they use a disc to smooth the edges. This is how my side glass was made, I would assume the windshield would be similar.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device Last edited by protrash64; 04-29-2010 at 11:12 PM. Reason: spelling |
#219 |
i have heared of people cutting the glas with a anglegrinder on yalope but my thought on that is that the vibrations and the tention is enough to splinter it
if i was to do that i put the glas in a big container with mineral oil in it untill its a little above the glass that way you can still get to it with the anglewheel without dunking the electric part intoo the oil and the vibrations get dampened should the grinder drop out youre hands you can still use it since the mineral oil doesnt conduct electricity they use that stuff even in transformers hanging of those electricity poles to keep them cool and somewat quet and should it shatter the parts dont fly
#220 |
I have seen shows on TV where they score both sides, then put lighter fluid on it. They light the lighter fluid to melt the plastic and snap the glass. It looks so simple on TV. Maybe you just need to video tape it to go smooth.
#221 | |
i can immagine when you have done it more often you get a routine that makes it look simple
#222 |
1961 crewcab
check this link out: http://www.cadvision.com/blanchas/54...indshield.html
this is the process I plan on using for cutting the windshield.
#223 |
One day...
Thats pretty cool but going to take a while huh. Let us know how it turns out.
#224 | |
Daring to be Different
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
#225 |
Redneck Hillbilly
Amazing build, I love the crazy customs. Can't wait for the finished product.
