Old 06-26-2010, 08:26 AM   #1
gmcer
original motor-best oil type
time to change the oil in my 50' gmc 228 its original with 63,ooo miles a valve job runs sweet with some blow by . if you you guys got some suggestions on wieght or synthetic or non that would be great. thanks in advance!
gmcer is offline   Reply With Quote
Old 06-26-2010, 12:08 PM   #2
'58Patch
Re: original motor-best oil type
As far as I know, you cannot use synthetic oil for the '47 - '66 generation engines. Someone correct me if I am wrong on that.
Napa sells an oil specifically designed for these engines. Not sure about the weight but that can be found out easily enough.
View my truck's story here: http://67-72chevytrucks.com/vboard/s...d.php?t=402996
'58Patch is offline   Reply With Quote
Old 06-26-2010, 12:10 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
I would use a diesel oil, something like Shell 15w-40 Rotella T or
Shell Rotella T6 Full Synthetic 5W-40
Old 06-26-2010, 12:21 PM   #4
John Gilbert
It doesn't matter if you run synthetic or not, but the oil has to have ZDDP in it which is a zinc additive. Zinc was eliminated recently in most oils because it shorten the life of catalytic converters.
Running without zinc will destroy the valve train in a flat tappet motor.
I run synthetic in everything I own, and pretty much wouldn't run anything else.
I know back in the late 60s, early 70s, I ran Valvoline 30wt non-detergent in my '47 216, and 49 Jimmy with a 270.
The topic of oil can get pretty controversial — just make sure you have zinc.
John Gilbert is offline   Reply With Quote
Old 06-26-2010, 12:32 PM   #5
JMR5
JMR5's Avatar
Valvoline VR1 Racing oil has zinc in it and usually comes in either 10-30 or 20-50 weights. Autozone usually carries it. Another option is to use you favorite oil and just put in an additive like STP, which has zinc.
JMR5 is offline   Reply With Quote
Old 06-26-2010, 12:43 PM   #6
'58Patch
Good to know, thanks guys!
Old 06-26-2010, 04:18 PM   #7
alden
alden's Avatar
Not to hijack, but is anything different on the 55-59 235's? I haven't driven it at all since I changed it so if I need to change it out again I can, but I just went with a 5W-30 Valvoline oil mix.
What about transmission/rear-end, anything special required to accommodate the old mechanicals?
alden is offline   Reply With Quote
