gets board easy.......
Re: trimming lower control arms
u normaly grind the stop off also, i like the travel
Grinding the stop off only increases the problem if the wheels rub. Once the stop is gone, you have to remove more material because the steering arc will slightly increase (close to, or in bind).
#4 | |
Read my statement again.....
