01-03-2011, 08:49 PM | #1 |
GMC paul door seals are great!
My bodyman tried to glue on some stock type door opening seals after finishing up the paint work on my 68 and they were awful. Did not want to stick or stay in position.
I picked up a set of the push on type with metal insert inside from GMC Pauls and the are great. They took a little work to get installed (still need to pass side) but now they actually stay in place and look much cleaner, especially the inside edge. I highly recommend this upgrade. I will try to post up some pics soon, althought I am sure there are some pics floating around here on the forum. Thanks GMC Pauls for a great product and a reasonable price and fast shipping. BP 68
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 Last edited by N2TRUX; 03-07-2013 at 10:57 AM. |
01-03-2011, 08:53 PM | #2 |
Under Construction
Re: GMC paul door seals are great!
That's good to know because I've got a set of those laying around. Gotta get my truck back together and painted first tho. Someday....
72 chevy 4x4-my project 67-72chevytrucks.com/vboard/showthread.php?t=368210 94 Nissan 4x4-Daily Driver and off road beater 03 Saab 9-3 -tripper 90 Polaris Trail Boss- 2 Stroker |
01-03-2011, 09:18 PM | #3 |
Hey, new (?) guy here.............
I got the Complete Cab Rubber kit from them, but it doesn't have the push on seals in kit.BUMMER!!!!!!!!!!! It sure would help his sales if he had more pictures\better descriptions on his site. |
01-03-2011, 10:04 PM | #4 |
Good news to me too. My truck is all finished but I've shied away from the door seals. I've never bought rubber of any kind for my truck that was worth a darn.
01-03-2011, 11:24 PM | #5 |
The door seal are one of the few things I would to go back and do again. Like a dummy I went to HomeDepo looking for some type of glue to glue on my new rubber set. The guy there told me that the Gorilla glue would work... That was the most messy stuff I have ever dealt with. The seals are glued down good, but I have some yellow dried up snot looking stains sticking up from the seals in places. Im for sure going to try some of the GMC Pauls sets.
Did the doors close good after you installed them or the doors sticking out a bit? |
01-03-2011, 11:28 PM | #6 |
no pics????
01-03-2011, 11:34 PM | #7 |
wish i could get those shipped up to Canada
01-03-2011, 11:38 PM | #8 |
Do the stock seals have the metal insert? or are they glued? Mine are in great shape but don't know if they can be removed and then put back
I have my cab down to the metal and I have been avoiding removing, tearing or replacing the upper seals to paint the part behind the seals. I should do it right and replace them. thanks for the tip. easier to pull the trigger if i know the replacements fit correctly. Not to doubt you but any noises, whistles or hisses through the doors? Thanks Again
Ed F 1972 Sierra Grande White Top Medium Olive 402 bb / Camper Stock, Loaded, Straight & Aged Nicely, No Tilt Original Resto would be nice $ |
01-20-2011, 02:34 PM | #9 |
Sorry for no pics, I will try to get them up soon. Been a busy and cold new year. My doors don't stick out and require about the same amout of effort to close as with factory style seals.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
01-20-2011, 03:00 PM | #10 |
67cheby
i bought the same ones for my truck cant wait to have it painted where i can install them, good to hear that you like them
01-21-2011, 08:49 AM | #11 |
Glad you like them, I think they are the best also over the glue in style. The easiest method to install them is using a rubber mallet to tap on the seal to install it, using the rubber mallet gets them to conform best to the mitered upper corner and fully seats it on the door cab seal lip. You should also cut a angle notch on either end where they meet under the door sill plates so that the cuts form a inverted /\ shape this allow air to expell from the rubber bulb seal as the door closes ( this allows the doors to close much easier than if you butt the 2 ends tightly together and doing it under the center of the door sill plates hides the cuts ) and it also allows any water that gets into the cab to drain out.
For those that order our complete cab rubber kits we offer the option in the cart to upgrade from the glue on door seals to our push on version. In years past we intially tried using the late model truck door seals such as 88-98 or 82-93 S10 but we found the bulb seal was almost 3/16" thicker than the stock seals which mean't door adjustment & latch adjustment to get them to close well using those styles, about 3 years ago though we got with our manufacturer and came up with a similar seal as the 88-98 trucks and 82-93 S10 seals that is only apprtox. 1/32"-1/16" thicker than the stock glue on seals and since then you no longer have a problem using alot of effort to close the door fully and it eliminated the need to adjust the doors to reduce the effort involved in closing the doors. Paul @ GMCPauls |
01-21-2011, 09:35 AM | #12 |
I've never seen these. Can they be installed,removed,and reused easily? As I recall,the '90s truck ones do,so I assume the answer is yes?
01-21-2011, 09:51 AM | #13 | |
Paul @ GMCPauls |
01-21-2011, 10:06 AM | #14 |
This type of seal sounds almost too good to be true! I tried to find them on GMC Paul's web site but it just listed the original style seal, unless I missed it. How much did a set cost?
01-21-2011, 10:09 AM | #15 |
67cheby
if i am not mistaken mine were $49.95
01-21-2011, 10:24 AM | #16 |
Don't worry if GMC pauls doesn't ship to Canada, go to a wrecker and get Dodge Dakota push on style from the 90's, fit like a dream and waaaay cheaper. If you want new go to the dealer.
Wes and Classic Heartbeat sometimes has the push on style as well.
71 GMC 1500 LWB |
01-21-2011, 10:32 AM | #17 |
This is good news, I just ordered a set. I'm going to try them out before I paint my 72.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
01-21-2011, 10:36 AM | #18 |
Great! That puts a plus on top of the other pluses. Way to go!
01-21-2011, 11:03 AM | #19 |
Marking for reference
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
01-21-2011, 11:05 AM | #20 |
You'll find them only listed on our truck weatherstrip page not on our Blazer or Suburban weatherstrip pages due to the Blazer difference on ends of seals and the Suburbans havea 90 degree corner we've never tried getting these to conform to so we don't list them for them either.
You can go to the page they are on at the following link http://www.gmcpauls.com/Pickup.htm Part# 2660241 $49.95 pr & $12.75 shipped priority mail insured anywhere in the USA Paul @ GMCPauls |
01-21-2011, 11:54 AM | #21 |
I have Precision seals on my truck, and my doors are a bit hard to close. If I were to swap out to these, do you think it will make a difference in the closing pressure? Thanks
01-21-2011, 12:24 PM | #22 | |
Paul @ GMCPauls |
01-21-2011, 12:36 PM | #23 |
Do you have the part # for them I looked on your web site and only found one set is that them. thanks Gary
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
01-21-2011, 12:44 PM | #24 | |
01-21-2011, 01:58 PM | #25 | |
