03-01-2011, 01:00 AM | #1 | |
Sofa King Crazy!!
Re: Project: 1967 C10 Small Window
We use airplane stripper and a razor blade, sounds like a lot of work but it does make it quick. Put it on with a paintbrush, let it sit for 20 minutes then use the blade on it. Repeat as necessary.
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
03-01-2011, 01:04 AM | #2 |
Yep including myself haha. Sweet that sounds like a good idea. I think I'll try it.
03-01-2011, 09:06 PM | #3 |
Alright I promised some pics so here they are. I wasn't able to spray the high build primer tonight because I decided to seam seal the drip rail where I had removed the previous sealer. I'll wait for that to get a little harder overnight before I clean it up. I also painted my bell housing and got a 600 cfm Holley no charge courtesy of 62ls1! We bought the truck from him and he's been huge help throughout the entire build and I can't thank him enough. We have the rebuild kit for the carb and I've also begun work on that.
03-01-2011, 09:15 PM | #4 |
I also cut out and welded this up. I reconstructed how the window frame originally was with the inside part of the dash as well as the outer part you see. And here's the rig I've been using.
Tags |
1967, small block, small window, stepside |
