03-04-2011, 01:12 AM | #1 |
Re: How To Video, LSx Wiring Swap Harness, 99-02 Truck Harness: 4 Wire Hookup
The pcm feeds cant take more than 10-15 amps from a direct short to ground, Running the PCM,(8)Coils,(2)O2 heaters,(8)Injectors,& a MAF sensor on the same fuse is asking for trouble. What AMP fuse are you planning on using?
03-05-2011, 05:18 AM | #2 |
NOT really the proper way to do it, why dont you show us something new or helpful and not just following what other websites recommend so you can get famous on you tube.
03-05-2011, 06:07 AM | #3 |
69' Chevy Stepside
Hey man, not trying to get famous just having fun with video editing. The reason I made the videos was to show people what was exactly involved in redoing a harness. As far as I know I have never seen any videos that show much about these harnesses and how to work with them. I now realize that we did do some things wrong and I should have separated out my positive wires so they can be fused separately as clinebarger pointed out. This was the first harness I did with all the wires together. Other than that what the heck did I do wrong? I've done a couple of these harnesses and never had a single problem.
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
