Old 05-12-2011, 10:47 AM   #276
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: How to: Ruin a perfectly good C10
Originally Posted by 67cheby View Post
HOLY SMOKES.....your going so fast your making me DIZZY !!
I agree.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 05-12-2011, 12:39 PM   #277
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by BB72CHEVKT View Post
I agree.
Haha- I don't have the luxury of being able to take my time- I have a wedding to (hopefully) drive it to in 5 weeks...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is online now   Reply With Quote
Old 05-13-2011, 12:44 AM   #278
gringoloco
A guy with a truck
gringoloco's Avatar
While I have the windshield out, and easy access to the dash pad, I decided to go ahead and dye it with the Corvette Bright Blue since it was a little faded compared to the armrests. I also shot the rubber cover for the rear view mirror (which had turned kinda green) and re-installed it and the visors with new stainless hardware. MUCH better without rust!
-Chris
Old 05-13-2011, 12:59 AM   #279
gringoloco
A guy with a truck
gringoloco's Avatar
Then came the real work of the day: stripping and smoothing the bedsides and readying them for primer. Lots of repetitions of sanding and filling, but I think I finally have them close. I will wet sand and check for any spots I missed, as it is easier to see imperfections when it's all one color. Hopefully we will see some blue tomorrow
-Chris
Old 05-13-2011, 07:57 AM   #280
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
You're really getting after it. Looks good!
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 05-13-2011, 08:39 AM   #281
mcbassin
Still Learning
mcbassin's Avatar
Man you aren't playin around with this project. Hard to believe how fast you're moving. It looks great too.
Old 05-13-2011, 11:08 AM   #282
VA72C10
VA72C10
VA72C10's Avatar
Awesome progress. Interior looks GREAT!!!
Old 05-13-2011, 11:12 AM   #283
67cheby
67cheby
67cheby's Avatar
Wow
67cheby is offline   Reply With Quote
Old 05-13-2011, 02:26 PM   #284
gringoloco
A guy with a truck
gringoloco's Avatar
Wow
Thanks fellas! I'd say it's turning out decently. If I were doing a full-on restore, it would be much better quality, but this will work for now
-Chris
Old 05-13-2011, 02:37 PM   #285
gringoloco
A guy with a truck
gringoloco's Avatar
Today's lesson, boys and girls, is to ALWAYS check and double check your mix ratios and air pressure settings BEFORE you start painting.
I wet sanded the bedsides, which had a few small issues, but were deemed worthy of color, so I mixed up my HRF and got to it. Problem is, I was just spraying base/clear, so I had the wrong mix ratios in my head. Twice as much hardener and reducer as necessary yields a runny, dripping, sagging mess. Low air pressure results in a spatter-paint effect. Both of which are not conducive to good-looking paint on your truck...
Now I know why my clear came out so crappily, too. Seems I have a bad habit of resting my pinky on the air pressure fine adjustment knob. At least with double the hardener, the paint will be dry sooner, and I can fix it sooner
-Chris
Old 05-13-2011, 02:43 PM   #286
67cheby
67cheby
67cheby's Avatar
man....i am shipping my truck to you tomorrow....i expect it back by the end of next week
Old 05-13-2011, 02:51 PM   #287
Number98
Prestige Worldwide
Number98's Avatar
You are really knocking this thing out man!
Looking sweet!!
Number98 is offline   Reply With Quote
Old 05-13-2011, 05:13 PM   #288
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
looks good in the pics
Old 05-13-2011, 07:59 PM   #289
gringoloco
A guy with a truck
gringoloco's Avatar
Haha- YOU need to get to work
Looking sweet!!
Thanks! I'm working on a deadline here- starting to feel the crunch...
Yeah, it laid out nicely for the most part, just got a little sputtered at the rear of the driver's side and a few sags/runs. All sanded down and re-sprayed now; looks MUCH better
-Chris
Old 05-13-2011, 08:18 PM   #290
sourkraut
sourkraut's Avatar
Are you using a clear coat or just the color? If you are using a clear is it flat too or satin?
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 05-13-2011, 08:42 PM   #291
gringoloco
A guy with a truck
gringoloco's Avatar
Single stage urethane, with the flattening agent already mixed in. Just activate and shoot. It will be staying 'satin'
-Chris
Old 05-13-2011, 08:53 PM   #292
gringoloco
A guy with a truck
gringoloco's Avatar
A few pics of it dry. MUCH better this time around...
-Chris
Old 05-13-2011, 08:56 PM   #293
gringoloco
A guy with a truck
gringoloco's Avatar
Stripped the masking off...
-Chris
Old 05-13-2011, 09:07 PM   #294
gringoloco
A guy with a truck
gringoloco's Avatar
...and rolled her out in the sunlight
-Chris
Old 05-13-2011, 09:31 PM   #295
VA72C10
VA72C10
VA72C10's Avatar
Looks great from here!!!
So when do you paint the front end?
Old 05-13-2011, 10:03 PM   #296
gringoloco
A guy with a truck
gringoloco's Avatar
...So when do you paint the front end?
We'll see how things go tomorrow; lots of dis-assembly before paint...
-Chris
Old 05-13-2011, 10:54 PM   #297
Painter D
Painter D's Avatar
Pretty cool, keep it up
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 05-13-2011, 11:10 PM   #298
BACKYARD88
BACKYARD88's Avatar
Looking good!
-Mike Owen-
Old 05-14-2011, 09:11 AM   #299
gringoloco
A guy with a truck
gringoloco's Avatar
Looking good!
Thanks guys! Nice to see it all one color
-Chris
Old 05-14-2011, 09:29 AM   #300
67cheby
67cheby
67cheby's Avatar
looking great
