Old 05-24-2011, 01:06 AM   #1
Steve_aka_Violent_J
Steve_aka_Violent_J's Avatar
Thumbs up Can a 98 1500 rear axle work on a 63 3/4 ton?
I have found a rear axle from a (98) Chevy 1500, 3.41 Ratio (I think). I was wondering if it would work on my 1963 3/4 ton pick up. The truck will be a cruiser. occasionally hauling garbage to the dump. At work we have all the tools to cut, grind, weld and modify. I can go buy parts we cant fabricate.
Truck: 1963 Chevy Long Bed
engine: 327 (nothing special)
Tranny: 350 turbo I believe.
Front suspension: Early Classics Drop Spindles disc conversion. Haven't yet decided on what year to go with on this set up. but was told from 71 to 81 will work.
Rear suspension: Springs
Price for complete axle: $200
My build:
http://67-72chevytrucks.com/vboard/s...d.php?t=461989
Also looking at a 76 rear. price $250
All input is welcome. Im open to all advice and suggestions.
Thank you,
Steve J.
Steve_aka_Violent_J is offline   Reply With Quote
Old 05-24-2011, 03:40 AM   #2
Blue666
Re: Can a 98 1500 rear axle work on a 63 3/4 ton?
I would also like to learn more about these axles as I have seen some of these trucks with factory rear disc brakes. Does anyone know what other ratio's are available?
Blue666 is offline   Reply With Quote
Old 05-24-2011, 02:11 PM   #3
Steve_aka_Violent_J
Actually this one is drum brake not disc.
Old 05-24-2011, 02:46 PM   #4
jimmydean
jimmydean's Avatar
Not sure on the axle tubes, but other than welding on perches (if you have trailing arms) it should be an easy swap. Not sure of the width, either.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-24-2011, 08:52 PM   #5
Steve_aka_Violent_J
I just found out the width is about 64 inches while mine is around 60 1/2 inches. this was not a precise measurement but it is a nearly 3-4 inch difference. that can be significant when lowering. not to sure I want to take the chance.
Old 05-24-2011, 09:03 PM   #6
Steve_aka_Violent_J
Last Update:
Old 05-24-2011, 09:05 PM   #7
Steve_aka_Violent_J
also doesnt seem complete. I will try to find more.
Old 05-24-2011, 09:19 PM   #8
jimmydean
jimmydean's Avatar
Depending on your wheel choice, you can make up the difference in width with offset.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-24-2011, 09:36 PM   #9
Steve_aka_Violent_J
Rear suspension:
Old 05-24-2011, 09:41 PM   #10
Steve_aka_Violent_J
Very true, I haven't just yet wrote it off. I will need to buy custom rims any way so it might work out in the end. I just want to do all my homework before i commit. and looking at my last post it seems i have many more options.
Old 05-25-2011, 12:06 AM   #11
Captainfab
60-66 Nut
The '88-'98 rear differentials measure 64-3/4" WMS to WMS. I don't remember the exact measurement on your original C20 rear differential, but it is somewhere close to that. That said, the '63 to early '70 C10 differentials measure 62" WMS to WMS. Then the late '70 to '87 C10 differentials measure 63-1/2" WMS to WMS. So the '88-'98 is a bit wider than a C10 differential in your truck. It may work if you are OK with running wheels with a deep backspacing. Personally I would look for a '71-'87 rear differential.
Old 05-25-2011, 01:41 AM   #12
Steve_aka_Violent_J
Thanks. Im not sure what the correct way to measure. I've. Read everywhere. And figured it is from where the rim and drum meet to the otheside of the axle
Same area. And if I'm correct my c20. Is 60 inches wide. Give or take 1/2 inch. With that said, are the 71-87 similar In width? I measured from inner wheel well to inner wheel well is around 50 1/2 inches. Outer wheel well to outer is around 77 inches.assuming my son put it in the right spot.I can get a 76 for 250. I think its to much personally. Its sitting in a junk yard.
Old 05-25-2011, 03:52 PM   #13
jimmydean
jimmydean's Avatar
WMS is wheel mounting surface. It's the most accurate measurement.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-25-2011, 08:50 PM   #14
Steve_aka_Violent_J
Its been a while but today I stopped by this old wrecking yard called Turners. You talk about knowledge, this old man has it. I told him what I was doing and he already had an answer and the solution. basically he siad measure your WMS and we will find you a match. he's charging 300 plus the core. smart, charge three hundred get my axle and sell that one for 300. crazy old man knows how to swindle. If you need parts for any project I'm sure he has it. heres a link.
www.turnersautowrecking.com
4248 S. Willow
Fresno CA 93725
(559)237-0918
this is not trucks only its everything.
Cant believe I forgot about it.
1963, conversion, rear axle, suspension, swaps
