Old 09-04-2011, 12:44 AM   #176
mosesburb
I had a V-8
mosesburb's Avatar
Re: #3 The Sickness Continues
If it will fit, it will work. The one in mine is out of an 85-91 Blazer/Suburban/Old body style P/U. You can also get a universal pump kit that puts a pump inline to your squirters. Your call on which one would work best, but it is some food for thought in case you find a reservoir that will work, but it doesn't have a pump in it, you can go with the universal inline pump.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 09-04-2011, 09:50 AM   #177
protrash64
Resistance is Futile
protrash64's Avatar
That may be the way to go! My truck came with the bracket but the bottle was missing. I removed the bracket for my headlite relays, but I could easily relocate that stuff and use an original style bottle with an inline pump. Thanx!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 09-05-2011, 01:32 AM   #178
Captainfab
60-66 Nut
On my '66 Suburban I used the original reservior, but added a '85 full size van washer pump. In the van, the pump clips onto the reservior bracket. So I added an area on the bracket on my Suburban to mount the pump, and connected the inlet side of the pump to the feed tube/cap on the reservior. I just powered it with a momentary toggle on the dash since at the time I couldn't figure out how to make it work with the factory switch. I have since found the info on how to do that, but I haven't had the time. Heck I haven't been able to drive my Burb since last summer
Old 09-05-2011, 12:52 PM   #179
protrash64
protrash64's Avatar
Excellent Cap'nfab!!! Just what I was thinking. Something simple and straight forward. I havent messed with the switch yet, but I figured I'd have it actuate a relay. Maybe the pump doesnt draw much??
I remember seeing a thread for a replacement tank but dont know what it was. I'm thinking the tank was the same as a Camaro, or something like that. I have spent no time searching any catalogs; I'll post if I find it.
Old 09-05-2011, 01:17 PM   #180
chad64chevy
chad64chevy's Avatar
protrash remember to post pictures too! i was wondering how do add windshield washers to my truck, just havent done any searching either, just a lot of thinking,lol!!
chad64chevy is offline   Reply With Quote
Old 09-05-2011, 02:32 PM   #181
mosesburb
I had a V-8
mosesburb's Avatar
You don't need a relay. The pump doesn't draw much and the contacts in the switch are huge compared to what is actually needed. This is long before the auto companies realized they can make things crappier, then sell more replacement parts.
Old 09-05-2011, 03:25 PM   #182
protrash64
protrash64's Avatar
Good point! I also figured that the pump doesn't run that long; not like headlites or an electric fuel pump.
I did find in Classic Industries catalog these items: bracket, jar, and cap. They also have a complete kit but no picture. Also listed are pumps from '64-'04. looks like this is going to happen!!!!
Old 09-05-2011, 08:43 PM   #183
protrash64
protrash64's Avatar
OK, update. Figured I'd call about the universal stuff and this is what I got!! Went to O'reilly's and they had a kit, ANCO brand (they also make wipers). It has a bottle with pump, new switch,wiring, and hoses. 40 bucks......no brainer for me. The switch is under the plastic bag with the 2 copper lines they supply in case one needs to make their own squirters. I may need to get a 'T' fitting and thats about it. Next I have to sort out the switch and wire from the stock set-up.
Old 12-30-2011, 02:01 PM   #184
protrash64
protrash64's Avatar
Not really a truck update, but sort of...... heres a pic of the '66 bringing home the new air compressor so I'll be able to spray some love on the other two trucks. It's got enough capacity for spraying and its relatively inexpensive as far as compressors go. 60 gallon, 11cfm@40psi. Perfect for me. May finally have some updates on the other threads in the coming months.
And by the way, still havent put in a switch for the windsheild wiper spray set-up!!
Old 12-30-2011, 03:33 PM   #185
daverod
SSN 706
daverod's Avatar
You're going to love your compressor. I hooked my up with about 40 feet of 3/4" steel pipe. I sloped it down and put a drain on the end and some air taps off of that. Works great no water. The tap I use for painting I also run through a watercollector and filter. Looks like another good use for the creeper board. My dog uses mine for a skate board.
daverod is offline   Reply With Quote
Old 12-30-2011, 04:35 PM   #186
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Sweet, almost looks like mine
Nice to see the truck work'n. I'm putting mine to work tomorrow
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline   Reply With Quote
Old 12-30-2011, 05:18 PM   #187
protrash64
protrash64's Avatar
I was out in the garage trying to figure out how to plumb stuff....it's kinda bassackwards but thats where it fits. Cant wait to spray something!!!
Hey Tony!! You parked next to me @ Dinos but I didnt know what anybody looks like; I was wanting to talk to ya and then I saw you leaving. Next time we need name tags!!! I love picking up stuff in the '66. People always are checking it out and commenting; kinda fun.
Old 12-30-2011, 05:39 PM   #188
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
I hear ya! That's exactly what we were saying. Too many people and not knowing faces made it hard to find people. I'll supply the name tags and hand them out at the next one if Dino is cool with it
I love driving the GMC around for the same reason. It' just too fun
Tony
66 GMC LWB
Old 01-02-2012, 06:45 AM   #189
C@rnut001
Wanted to say that you have a great daily driver here! Keep driving and improving it over time. I also think it is great that you got a new air compressor. Hope your new year goes well!
Keep up the daily "classic" truckin'!!!
C@rnut001 is offline   Reply With Quote
Old 01-08-2012, 02:47 AM   #190
TimE
Hey Y'all!!
TimE's Avatar
Keep it up Jeff. Truck looks nice.
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 01-08-2012, 10:37 AM   #191
protrash64
protrash64's Avatar
Nice to hear from ya Tim!!!! You got off in the rough when you put the Duster in the avitar.
Old 01-16-2012, 10:59 AM   #192
dracko
dracko's Avatar
Nice work! How are those 4" drop springs working with heavy loads?
I am thinkin about dropping my '64 with those in the rear, but still haul my bike and stuff around town, don't want it bottoming out.
Thanks.
dracko is offline   Reply With Quote
Old 01-16-2012, 11:11 AM   #193
protrash64
protrash64's Avatar
Thanks.
Hey dracko.....these were 4''HD springs from CPP. I bought them for my 'burb originally. I think they left the 'HD' out. They ride nicely but with a load Im sitting on the bump stops. I have carried lumber, retaining wall block, the compressor, and other assorted construction stuff. I'm not sure if they would tighten up if they could travel farther without hitting the bump stops, if that makes sense.
I think I would seriously consider putting in bags with a compressor, or dont go this low.
Old 01-16-2012, 11:22 AM   #194
dracko
dracko's Avatar
Okay thanks alot for the info man. I also thought they might hold up better since they're HD, but obviously that isn't the case....at least the ride is smoother I guess!
I'll have to look into 2" drop springs in the rear with 2" drop spindles up front then.
Old 02-20-2013, 10:24 PM   #195
64LBSS
Hey, look what showed up on C/L last nite!!! No less than a set of 6-lug Rally wheels plus spare. Wonder where they are gonna end up?
Can you tell me what year model Rally's those are.. thats EXACTLY what i want !
64LBSS is offline   Reply With Quote
