Can I run coil-over shocks instead of coils and regular shocks?
I want to keep the trailing arms and track bar and ditch the coils. What weight capacity and length would I need? Has anyone done this? Thanx in advance Dano
![]() ![]() It ain't yours, if you didn't build it! |
#2 | |
Re: Rear coilovers on a '69 c10 lwb!
There is really no reason you can't...but you had better reinforce the shock mounting points, or better yet reengineer something stronger. The stock mounts were never designed to support the weight of the truck.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Thanx Longhair.
I never thought about the mount points. I'll have to check out some sites to see how it's done on other vehicles.
Insert Title Here
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
Insert Title Here
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time |
Insert Title Here
thats the same link i gave...lol
If you are going to add the coil-over shocks anyway, why the need to do away with the coil springs? I guess what I ask is other than added weight (20 - 25 lbs) what does it hurt to leave them under there?
I only ask out of curiosity and because I have absolutely NO experience with coil overs. Last edited by Shane; 03-02-2009 at 01:57 PM. |
Well.....I guess I can tell you guys. I want to alter my wheelbase....like 12 inches forward....w/o cutting the frame. This would put the rear axle right under the "frame hump". Just wanted to experiment with a LWB frame I have, since I can't seem to sell it.
Thanx Lo and Wild
![]() ![]() It ain't yours, if you didn't build it! Last edited by Dano69c10; 03-02-2009 at 05:36 PM. |
Insert Title Here
you going for this style?
#11 | |
i've seen coil spring rear ends with a coil-over shocks used as a "helper" springs and it seemed to work without any issues ... how would this be any different?
I hear what your saying, and agree. I think thoough that you'd want the coil spring to not be touching though unless its at load, like the helper leaf on some of our trucks. I think he's thinking having both springs touching permanently at the same time, which would be a super stiff ride w/ that many springs going on w/ no load.
I'm not sure how the helper coilover spring works as I've never seen them. I would imagine though that it works as leftcoast66 said. It doesn't support any load until there is a heavy load in the rear. I would also imagine it has a really high spring rate, which would make it a very stiff ride.
#15 |
i know im reviving a dead thread but when i got my 72 c10 it had the coil over shock helper shocks or whatever there called besides the fact the shocks where 15+ years old the ride wasnt super stiff i actualy think it was nicer then how it rides now with just regular shocks now it rides like a water bed not fun when hitting rail road tracks or bumps glad i found this thread though ive been wanting to convert to coil overs without going with a 4 link setup like my friend did and loosing most my bed
1972 c10 mild 383 3 speed on the tree It finally happened. I got the GPS lady so confused, she said, "In one-quarter mile, make a legal stop and ask directions." ~Robert Brault, |
#16 |
Old member
I can't find that kit any where. I tried I ended up with this one.
http://67-72chevytrucks.com/vboard/s...d.php?t=477839 Neither of those links worked for me either. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#17 |
I put them on my 71 and the ride is so much better than coils with even a good shock. I think I have 220lbs on the right and 200lbs on the left.
#18 | |
Old member
![]() Quote:
#19 |
I cobbled up my parts from used racing stuff my buddy had off his late model.
#20 |
How makes that coil over set up
