How many "Hot rods" used as Daily Drivers?
How many out there have a truck with around 350hp+ and drive them everyday? Have any problems and also what engine do you have and how many mpg?
Truck and auto performance nut
Re: How many "Hot rods" used as Daily Drivers?
well....mine is my driver...tho its not daily as I don't do a 9-5 (or 11-7 for that matter) any more.
![]() I like this shot: street trim: ![]() track trim...tho I I'm thinking on getting a smaller set of tires ![]() Combo is supposed to be good for 500+/- hp at the crank. No problems but then everything is either new or rebuilt. This is no economy vehicle and mpg numbers haven't been taken. It does have an overdrive trans to drop the rpm's on the highway. If I was concerned about using it as a daily...I'd have left the efi on the 6.0L. Install a late model efi motor (4.8, 5.3, etc) and add an overdrive trans...and as long as everything in your truck is solid... it'd be as dependable as a new truck is.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Grandpa in the rustmobile...
I DD mine (dunno if its 350 hp lol)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
71 K-10, Crate 350/330 hp, th350, 11 mpg
I die keeping the old girl full of gas, but I try to relieve the pain by thinking about all those car payments I don't have to make. Other than the engine, it's not really a hot rod. Skinny tars and no lift. |
Happy to be here
![]() Join Date: Mar 2000
I think you need to up your HP requirements before you consider it a "Hot Rod". These days, 350 is below standard on late model trucks and SUV's. My wifes 07 Denali has 385hp, and the new Jeep SRT8 will have 490hp
Well call it whatever you want, Hot Rod or not, I think everyone understands the question. I originally posted this in the 73-87 forum and then it was moved to here. It was originally intended for vehicles that arent as new as the ones you named.
Happy to be here
I understand your question and your intent. These days your topic needs specify if you intend to run a carb or injection. With a carb, much more than 400hp is limited in street function. With EFI, a 500HP streeter is become average with the LSx powered crowd.
Ok I meant with a CARB.
I drive this as much as possible! It's got a 327 with roller cam and 150 shot of Nos.
Problems-trying to drive with caution and keeping an eye out for the Police Cons-lopey cam,high stall and loud exhaust Pros-it is fun to drive,gets around nice,attracts attention everywhere I go Gas Mileage-YOU GOTTA BE KIDDING ME,you don't drive something with a Carb and HP and expect decent mileage they don't MIX Especially the way I drive but then I put the pedal to the metal ![]() If I replace my motor I'm going with a LS1 then I'll worry about mileage |
Sweet truck Indian, Yeah I know that a truck like this will get terrible gas mileage. I was just curious as to what other people actually got.
Even tho I'm not running carbs on my little 383, this is what gets me around. My only problem was way back when I ran biased ply tires on the back and it would start raining. Glad they came up with radials in my size. In town it is kind'a hard to measure mpg but I do get around 1 1/2 tpw (tanks per week). Good for 10 mpg on the highway.
Joe __________________________________________ 1975 C10 "Questions are a sign of intelligence indicating a desire to eliminate ignorance" |
#12 | |
With the thought of going FAST we lower our gear ratio down. I'm running a 4:10 not really a cruise gear. ![]() It's easier to put gas in because I'm not making payments on it. ![]() |
CoggedBelt 75,That is a nice set up you have there!! That polish job is a lot of work isn't it? Is there any lag on take off with a blower?
~Rest In Peace~
no lag here blower whines up real fast ,depends on the pulleys set up too
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
#15 |
You are exactly right Indian. NO PAYMENTS makes it not hurt so bad. Lol
#16 |
Instant response with mine. Not as hard to keep things shining as one would think. I polished about every other month and wipe it down with a damp cloth as needed.
Joe __________________________________________ 1975 C10 "Questions are a sign of intelligence indicating a desire to eliminate ignorance" Last edited by CoggedBelt75; 12-21-2011 at 05:38 PM. Reason: oops, wasn't finished with post |
#17 |
Thanks Guy's,I don't have any expierence with a blower! I would really like one though,it would look right at home in my model a
#18 |
The One And Only !!!
Well,
Even if my pockets were deep enough I couldn't bring myself to DD my 97, People around here are ![]()
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
#19 |
LIGHT' EM UP!!!!!!!!!!
"N2TRUX" Sorry DENALI'S dont qualify as a hotrod. Dont get me wrong those Denalis with the 6.2 will flat out move but what the question is talking about our classic chevrolet trucks. 14mpg and less haha
![]() ![]() ![]() BONDO IS YOUR FRIEND WOULD YOU EVER USE YOUR FRIEND ![]() 1972 custom 10 longbed current 360 building a racing 355 |
#20 |
I have been driving this except when its raining. BBC, TH400 and 9 inch with 4 link. I don't even try to figure gas mileage. Only thing I plan on doing to it is getting rid of the ground effects.
#21 |
BlahBlahBlah
Well, and this is just my opinion =) I see a lot of hot trucks, but no hot rods.
#22 | |
Just what is the defination of a HOT ROD! I know what a STREET ROD is-1948 and earlier But Hot Rod escapes me |
#23 | |
What is a hot rod is surely in the eye of the beholder ![]() From Wikipedia..........Hot rods are typically American cars with large engines modified for linear speed. The origin of the term "hot rod" is unclear. One explanation is that the term is a contraction of "hot roadster," meaning a roadster that was modified for speed. Another possible origin includes modifications to or replacement of the camshaft(s), sometimes known as a "stick" or "rod". A camshaft designed to produce more power is sometimes call a "hot stick" or, here, a "hot rod". Roadsters were the cars of choice because they were light. The term became commonplace in the 1930s or 1940s as the name of a car that had been "hopped up" by modifying the engine in various ways to achieve higher performance.
#24 |
I agree with Joe here, The only thing I'd touch is the GOOO pedal ! ![]()
#25 | |
BlahBlahBlah
![]() Definitely some cool trucks for sure though.
