I purchased this truck a few months ago and finally got some time to get it in my father's shop the last two days. Here are a few pics of my progress thus far. Thought I would throw a few pictures out and see what you guys think.
![]() Upgrade plans: 385 Fastburn ECE 4/6 American Autowire Blue/White Two-tone Mar-k Full Trim or NOS Huges 460L overdrive and all the little things to get back together in great condition. Follow along and please post any suggestions, ideas etc... Any advice is appreciated. THANKS! Last edited by LakeAnna; 03-31-2012 at 08:15 AM. Reason: add information on build |
Re: 72 Not sure what to call it yet resto!
some more...
Looks like a decent start...Good luck with the build
____ ______//__{\_____ ,/_(O)__/____/_(O)_/ |
A little history: I've been looking for a short bed on and off for the last ten years and finally the timing and cash worked out and I got it a few months ago. The previous owner started to redo the truck and had some personal issues and it sat in his shop since 2006. He purchased a Fastburn 385, threw it in (really) and never even fired it up. The motor has been sitting in it since late 07. It has some rust under the cab but all in all it seems really solid.
I've gotten tons of ideas from reading on here the last two months so here goes. Tomorrow I'm going to get chassis paint and some primers etc. My Dad has two pallets of media so let the games begin if the weather stays nice. |
Good clean start.
Any big plans?
My build thread for Project TiC TaC/Jazzmin Oh Yeahhh Cheap work is never good and good work is never cheap. Lesson = learn to do it all the right way on your own. ![]() SqueegeeMan |
Plans are to get the truck back to the origianal paint scheme two tone. I been trying to decide what color to go with. I like the chevy blue of that era.
3.5/5 drop with spindles and springs... this changes to in my mind I want a lowered truck but I know it kills the functionality to some degree. I got the truck and it only had the upper trim on it which looked okay but I was thinking of putting it all back if I can get decent pieces to replace them. I've been told Mar-k has good stock for the trim?? It has buckets and a console now in need of attention... I also have a bench seat in great condition I could go with if I want. Wheels??? It has the rallys on it now and I like them but will look at something more modern like I see on here alot. |
![]() Join Date: Sep 2010
Looks like you are doing this right. Love to watch the progress. you are not far from me so may have to come see in person.
#8 | |
![]() Quote:
Depending where you are 33 is a decent route also. I got some dupont chassis paint yesterday to use on the frame and underside of the the truck. Waiting on cab supports before I get everything scattered all over the place... |
Thanks. I will shout out if I am coming to see if it suits you.
Dave |
VA72C10
![]() Join Date: Mar 2008
Looks like a pretty solid overall starting point. I'm sure the media will reveal some more rust but you'll be well ahead by getting it down bare and being able to take care of it all so it doesn't come back soon after paint.
Sounds like a good plan! the drop you're looking at would still keep it plenty functional. Looking forward to the build!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#11 | |
It will be a nice build regardless of what is uncovered... Pics to follow here in a moment. The sand blast machine is home built and is not happy with humidity or good weather for that matter. ![]() |
ok
VA72C10
Nice looking parts!!!!
I hope to get somewhere I could use a blaster some day....would save me SOOO much time!!!
ok
#15 | |
#16 |
VA72C10
I might have to (mainly to see your project)
#17 |
Looking for a radiator support in decent shape... Where is a good source for a quality support that bolts up like it should? Any vendors on here that have them?
I need to find the pic of mine and post it up. Not in really bad shape just about a 10 inch area that was under the battery is pretty gone. Just realized the pic above shows the front but what is in bad shape is the bottom rail on the engine side of it. I guess this is pretty normal cause the parts truck I have is even worse in that area. Last edited by LakeAnna; 01-08-2012 at 11:17 AM. Reason: added info. |
#18 |
Update: Well, things are moving along pretty well so far. Couple of pics of the progress and the vicious cycle is underway.
#19 |
VA72C10
Nice progress!
The fuel lines are part of the vapor capture/ recirc. system that was a 72 only. there is a small hose that runs from the filler to the tank on a 72 only tank also that's part of the same stystem.
#20 |
Today was a beautiful January day for Virginia so I was able to take advantage of the warm weather and pressure wash the frame and bed. I have some SEM rust shield and dupont chassis paint in waiting. I guess my plan is to complete the frame and suspension/brakes first. I also hope ups will bring the tips tomorrow for the sandbaster (3/32). We got new aluminum oxide media that should do well. Any suggestions or ideas that might help me out? Thanks everyone.
#21 |
VA72C10
Nice toy there....makes moving the frame around much easier as well as getting under it
![]() What's the story on the yellow/ochre truck in the driveway?
#22 |
Well the Ochra/white top is my Dad's old work truck that has been in service now since about the mid 80's. It's been through several small block 400s and 60k into a crate 350. Dump bed with all aluminum body and sides. Rubber mat with a decent seat and vintage air for the ride home after a hard day.
I love that thing! It's a real work horse... The lift is left from my fathers Construction days ![]() ![]() ![]() ![]() |
#23 |
VA72C10
Very cool! Sounds like a super cool work truck! I need to get some things done around here and then definitely will make a trip up that way!
#24 |
![]() Join Date: Feb 2005
Nice shop.. Great project, I love 72s. Good luck with your build. Nice cleaver too
#25 | |
Tags |
1972 c10, 510 medium blue, cheyenne super, fastburn, lake anna |
