#76 |
Re: 67' C10 Build V8 Conversion & 700r4 trans
Man you have more people watching this than I have on mine, I'll try to help. lol.. Yes they make the firewall grommet for the clutch linkage in the firewall but I forget who sells it, but I changed my mind to an auto so I never got one, as you are, so why do you need it with an auto? you just want the plug for the hole then right? that I do not know.
I think the frame is just a little flimsy because the front susp/eng xmember is out, It is the main structure for the front. While im thinking about it, before you put the V8 in there you need to move the motor mount stands forward one hole, unless you like pulling the engine to get to your distributor.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#77 |
Thanks to everyone that reply'ed.
Hey 67c10rustbucket, I wanted a blank rubber plug to fill the clutch hole, now that I am going to Automatic, I don't want a hole in the firewall. In reading some where on this site it said that the Frame to motor mount, motor stands are different, between the I6 and V8, and Thanks for the note about moving the frame Motor stand to the front hole locations. Frame being flimsy, it is very flimsy, But once I have the three cross members back in (engine included) it should stiffen things up a bit.
1967 Chevy C10 Lwb I6-250ci 3spd manual trans Future Projects, Power Brakes, Front Discs, Power Steering, Paint Frame, New 350ci engine Bored .040 357ci Magnum, Vortec Heads, Comp XE262 Cam, Performer EPS Intake, 650CFM Carb, Rebuilt Trans 700r4, 2000-rpm stall, Completely Rebuild & Upgrade Front & Rear Suspension & Steering Components, Suspension Drop 3.5" & 5" Drop, 1.250 Sway bar, Last edited by westgl; 02-08-2012 at 11:02 PM. |
#78 |
Today, I sanded the firewall with scotch brite, & degreased it with a Wax & Grease remover.
I also blew out the Fresh Air Vent, I thought that I cleaned it out pretty well before, I took out about 4 handfuls of leaves and decayed garbage out of each side. But when I blew 120psi into the fresh air vent it blew out A LOT MORE crap, leave tree seeds, pine needles, what looked like Mudd, probably decayed garbage. If it is warm enough tomorrow, i will mask & Prime the firewall. I may even paint it. I received the KBS Frame coating kit in Satin Black today. So i am ready to finish cleaning the frame all the way back, I am also going to use it on the rear end.
1967 Chevy C10 Lwb I6-250ci 3spd manual trans Future Projects, Power Brakes, Front Discs, Power Steering, Paint Frame, New 350ci engine Bored .040 357ci Magnum, Vortec Heads, Comp XE262 Cam, Performer EPS Intake, 650CFM Carb, Rebuilt Trans 700r4, 2000-rpm stall, Completely Rebuild & Upgrade Front & Rear Suspension & Steering Components, Suspension Drop 3.5" & 5" Drop, 1.250 Sway bar, |
#79 |
Ok side note,
I have Two Porsche 914's a 1971' Porsche 914, that I has not had much attention. It has the stock Haha 80h.p. engine, I have been thinking that a Chevy 4.3L V6 230h.p. 275ftlbs of torque would be a great addition to this 1900 lbs. car. Maybe a summer project, after the 67' pickup is finished
#80 |
Well the wife got me a belated birthday gift.
Man she's gonna be pist off when she finds out. ![]() Guess what I did today.
#81 |
Well I had to try it out right!!
Shot three coats of Primer on the firewall. Here's the pics those pics are two coats
#82 |
Sorry i did not get any pics of the firewall with three coats primer, These pics are with two coats.
The Third coat was a heavy one. I must have been in a hurry to get some color on it.
#83 |
Here are a few pics with two coats of color.
There is a #144 in the trans tunnel, must have been a factory thing.
#84 |
I think that these were the pics with three coats of color
#85 |
Those pics dont look as good as it does in person, the pictures do not show the depth or the shine that you get when viewed in person.
#86 |
VA72C10
![]() Join Date: Mar 2008
Looks great!
.......But I think she'll be mad when she realizes not only did you buy the gun....but also that you used all of the aluminum foil ![]()
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#87 |
Arrr!!! Foiled Again!!!!
#88 |
67cheby
![]() Join Date: Sep 2008
you think she is mad about the gun....wait till she goes looking for her aluminum foil !! you are DEAD !!!.....but it was worth it firewall looks great !!
#89 |
Thanks Guys,
It looks much better than it did, Like new even, I am VERY Happy with the way it turned out. Well maybe the wife wont be so mad about the foil if i offer to paint her finger & toe nails.
#90 | |
#91 |
#92 |
Just kidding about the paint gun, my wife doesn't care. although, I could paint her some thicker eye lashes, maybe some thicker eye brows, maybe a unibrow, ok now she may be a little pist about the uni-brow comment.
The gun was $100.00, It is not a Cadillac/high end gun, but is considerably better than harbor freight, it has a very nice (finer) adjustment, the finer adjustment makes it easy to paint with out getting any runs. It is a much finer spray than you would get out of a rattle can. Cover fit on & came off well, a nice gun for the price. It was also easy to take apart & clean. The paint i was using is a very easy to use & spray on, it makes the amature look like a professional. It is a three part enamel with a hardner First thing i said after i finished was, "Wow!! Did i do that!!.
1967 Chevy C10 Lwb I6-250ci 3spd manual trans Future Projects, Power Brakes, Front Discs, Power Steering, Paint Frame, New 350ci engine Bored .040 357ci Magnum, Vortec Heads, Comp XE262 Cam, Performer EPS Intake, 650CFM Carb, Rebuilt Trans 700r4, 2000-rpm stall, Completely Rebuild & Upgrade Front & Rear Suspension & Steering Components, Suspension Drop 3.5" & 5" Drop, 1.250 Sway bar, Last edited by westgl; 02-10-2012 at 10:44 AM. |
#93 |
67cheby
i am impressed , the firewall looks perfect !
#94 |
Don't look at me, the spray gun and the paint is fool proof.
It did come out very nice. ![]() I think the Sata spray guns are $250.00+ to $400.00+, I did not want to spend that kind of many, since i dont paint very often. The one i got, the europro is actually considered a high end, in a few of the sites i went into. But not as good as the really good ones, like the sata that you can have for a lifetime, and use often, painting everyday with it.
1967 Chevy C10 Lwb I6-250ci 3spd manual trans Future Projects, Power Brakes, Front Discs, Power Steering, Paint Frame, New 350ci engine Bored .040 357ci Magnum, Vortec Heads, Comp XE262 Cam, Performer EPS Intake, 650CFM Carb, Rebuilt Trans 700r4, 2000-rpm stall, Completely Rebuild & Upgrade Front & Rear Suspension & Steering Components, Suspension Drop 3.5" & 5" Drop, 1.250 Sway bar, Last edited by westgl; 02-10-2012 at 11:05 AM. |
#95 |
Thanks 67cheby,
OK today i checked on my Powder paint guy, He hasn't started yet. But he said that they were going to start on my stuff today, hopefully. But ECE is going to ship the last of my order. Got the UPS Tracking No. And My Transmission is being held locally (they called to confirm delivery) until Monday when they will deliver it to my house. NICE!!!!!!! NICE!!!!!!! NICE!!!!!!! I have scheduled my time this weekend, (If i am feeling better) to clean the rest of the Frame, and Paint it. I hope it will come out as good as the firewall. I still have to order a Distributor, Coil, Water Pump, Long or short I dont know.
#96 |
I received a package yesterday.
A Large package on a pallet, it was a, 700R4 Transmission & Converter ![]() Today i am supposed to receive my last shipment from ECE. I hope I will receive my Parts back from the Powder painter this week. I still need to paint my Frame, I have been giving the firewall a few days to cure.
#97 |
I received my last shipment from ECE.
It had in the box, the engine to frame V8 mounting towers. LED Tail Lights Power steering brackets I Also received my Wheels Yesterday. All I need now is to get a call from the painter letting me know that my parts are ready, then i will be ready to start going back together. Once i get that Frame finished/Painted
#98 |
67cheby
WHAT !! you cant tell us all that without PICS !!
#99 |
I will take some pics but my camera knows that it is about 25 degrees out so It wanted to wait till it warmed up to at least 30 degrees out.
#100 |
Just mean, my new beautiful wheels you guy's can't see, haha.
