Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 02-14-2012, 10:13 PM   #1
amullis
amullis's Avatar
headlight switch wiring diagram?
Can any one send me a wiring diagram for a 68 headlight switch. I have just recently put my truck back together and now my headlights do not work.
Thanks AMullis
amullis is offline   Reply With Quote
Old 02-14-2012, 10:33 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: headlight switch wiring diagram?
These are two that I have. The second one is for the 69 and later. The 67 and maybe the 68 would not power the parking lights in the full out position.
Name:  Headlight Switch 1.jpg
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-15-2012, 09:40 PM   #3
Fixwhataintbroke
Enthusiast
Fixwhataintbroke's Avatar
Not to hijack this thread or anything but just have a question in hopes somebody could answer it. I installed relays for my headlights, then rewired it so that the lights come on and off only with the key. But now i'm looking to find a way to reverse the operation of the headlight switch. Basically, instead of being off when the switch is all the way in, i want it on when switch is in, and off when all the way out (still retain the on only with key on too). It seems all that's needed is to swap terminal 6 with terminal 7, correct? I know the idea is way out of left field but it seems like a nifty thing to do.
- Cole
1979 Chevy C30 w/ carb 454.
1992 Chevy K1500 w/ tbi 350. *Sold*
1997 Dodge Ram 1500 w/ Magnum 360 *Sold*
"Good judgment comes from experience. Experience comes from poor judgment." - George Washington
Fixwhataintbroke is offline   Reply With Quote
Old 02-27-2015, 02:01 PM   #4
JDSurge
Junior Member
JDSurge's Avatar
Hey guys, I have just purchased a rebuilt tilt column for my 72 Blazer and there is a horseshoe wiring connector but also a single wire with a spade connector. CPP said that goes to the bulb that lights up the gear indicator and that it should connect to the lighting switch but I don't see any place to connect it to. I think it should go to the dash light output but any ideas?
JDSurge is offline   Reply With Quote
Old 07-21-2015, 08:17 AM   #5
elkniks
Active Member
elkniks's Avatar
Mine looked factory and daisy chained from the heater controls bulb.
elkniks is offline   Reply With Quote
Old 09-10-2015, 02:15 PM   #6
Chevford
Smile Re: headlight switch wiring diagram?
Just wanted to thank VetteVet for the diagram!
Ive got a 41 ford that had a 72 headlight switch in that i replaced
with a aftermarket one and couldnt figure out what when where on the
new switch. This was a big help! THANKS
Chevford is offline   Reply With Quote
Old 09-10-2015, 11:40 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Glad to help as always.
VetteVet
Old 01-28-2016, 08:49 PM   #8
chipmyers
Here goes the first of many dumb questions..
I have reacquired a 68 that we built about 12 years ago. Not to get into to much detail but I'm redoing the electrical mess from the PO. A tractor switch was used for the headlight and the OEM is causing me grey hair. The only live lug is the HI/LO and NOTHING ELSE. Every thing else works with a 12 jumper wire so I don't think that's an issue. Ground is OK, went as far as a jumper from the switch to the battery. Any Ideas???
PS Thanks for the diagram was a lifesaver thanks to LMC's harness and lack of instructions.
chipmyers is offline   Reply With Quote
Old 01-28-2016, 09:50 PM   #9
ray_mcavoy
Welcome!
Are you feeding power to both the red & orange wires? Or just the red one?
The red wire is the 12V input for the headlight circuit and it only powers the light blue (high/low) wire when the switch is turned on.
This diagram is a bit misleading in the way it has the orange wire labeled as "dome/courtesy".
The orange wire is a 12V feed for the dome/courtesy lights. But it is also a 12V feed to the headlight switch and is used to power the parking / tail / dash light circuits.
ray_mcavoy is offline   Reply With Quote
Old 01-28-2016, 10:22 PM   #10
chipmyers
Just the red. Another 12 volt feed would explain the weird impedance readings I was getting fooling around with the switch. I'll go run another feed right now.
Thanks millions, that's why you ask questions.
Old 01-28-2016, 10:47 PM   #11
chipmyers
That did it....
Thanks again
Copyright ©2000 - 2019, vBulletin Solutions Inc.
