Old 08-16-2012, 07:37 PM   #26
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Project-GMC Slant Nose
Originally Posted by shok View Post
can you take the tailgate off and soak it in water for a day and see if that will loosen the bondo? I've always heard bondo will absorb water and expand. If thats true it might pop it loose without much work.
I have to find a container large enough to fit the tailgate in. If I use a wire wheel or flap disc I would have a dust cloud larger than the ones that be in Arizona.
69 C-10 Longbed Fleetside with a nice 91 TPI that smokes the tires.
Custom front disc setup from Kragen.
CPP 3/5 drop with front sway bars.
1968 GMC Project Slant-Nose
http://67-72chevytrucks.com/vboard/s...=1#post5542618
VDOG is offline   Reply With Quote
Old 08-16-2012, 07:53 PM   #27
shok
just make something up using plastic dropcloths if you think the idea is worth trying.
yeh i've had bondo situations like that and the dust is out of control just wirewheeling it or sanding.
1966 C10 250 with 3 on the tree Build Thread
Bunch of other cars no one cares about
shok is offline   Reply With Quote
Old 08-16-2012, 11:40 PM   #28
Tinkermc
not ready to post any pics yet but most likely very soon
Tinkermc is offline   Reply With Quote
Old 08-18-2012, 12:05 PM   #29
VDOG
Grand PooBaa Member
VDOG's Avatar
Cool!
Old 08-22-2012, 05:59 PM   #30
VDOG
Grand PooBaa Member
VDOG's Avatar
Removed the fenders, hood was already not attached. Decided to degrease the suspension and under carriage, not alot of grease. Think for now im going to just tighten up the suspension with new hardware, ball joints, shatf links, etc etc and some paint. Need to move it from the ground to a soild surface so I can tear down the suspension.
Old 08-23-2012, 08:25 PM   #31
VDOG
Grand PooBaa Member
VDOG's Avatar
Ok me and these engines, its a 327ci 350hp engine, in fact both of them are the same numbers. But I found a vortec engine and waiting to hear from the guy. So we will see.
Old 08-23-2012, 08:38 PM   #32
Tinkermc
glad to see progress being made
Old 08-24-2012, 12:07 PM   #33
VDOG
Grand PooBaa Member
VDOG's Avatar
Thanks for the support. I now have to take the 69 to the shop due to the frontend shaking.
Old 08-29-2012, 08:04 PM   #34
VDOG
Grand PooBaa Member
VDOG's Avatar
Filler on the driverside rear fender. I have never seen white filler, but it has a few cracks. Not ready to take it all the way down to the metal yet and the plan for now is to keep it black suede. So im good. I think.
Old 08-30-2012, 01:36 AM   #35
shok
Almost looks like old cracked gel coat on a fiberglass part
Old 08-30-2012, 12:16 PM   #36
VDOG
Grand PooBaa Member
VDOG's Avatar
You just might be right. Im going to have to take a better look, I did find fiberglass on the rocker. Thanks.
Old 09-01-2012, 09:33 PM   #37
hopped up
hopped up's Avatar
Keep up the good work vdog
hopped up is offline   Reply With Quote
Old 09-09-2012, 03:12 AM   #38
VDOG
Grand PooBaa Member
VDOG's Avatar
As I was sanding down the fender, I got past the white primer and on some
of the parts has pink filler under the primer. I figured thats what it is because its on a lot of areas of this truck. Even with the pink filler its not thick or caked on.
I figure some welding, sanding, and other body work, then I can shoot it suede again with a clear over it. I dont want to take this down to the metal just yet. So im going to leave well enough alone. I have already sanded down too much filler and found a spot that I need to refill.
Old 09-11-2012, 11:38 AM   #39
VDOG
Grand PooBaa Member
VDOG's Avatar
Picked up some POR-15 sample cans. One regular POR-15 and the other is POR-15 Chassis Black. Only applied the regular so far and impressed with how it turned out. So to keep cost down this is the way im going. After I pressure wash and wire wheel the frame first.
Old 09-17-2012, 07:47 PM   #40
VDOG
Grand PooBaa Member
VDOG's Avatar
POR-15 will be the paint. Use the 4 1/2 inch grinder with a wire wheel to clean the frame. Just not sure if I want it that shiney or not. Once I pull the engine and trans this week, I can paint up to the cab.
Old 09-17-2012, 07:53 PM   #41
VDOG
Grand PooBaa Member
VDOG's Avatar
I will be using the 71-72 spindles I already have (Thanks Johnoro) and will be adding CPP 6 lug rotors. Might keep them red, not sure.
Also going to powercoat my steering linkage bar that connects the inner tie rods. That will be either black or red. Again not sure.
Old 09-18-2012, 10:30 PM   #42
Dano69c10
Dano69c10's Avatar
Hey Vince,
Glad to see you making progress, my step has been sitting in the same spot I parked it when I got home from the Downey meet. I'm not sure when I'll get the cash to work on her again. I should probably tear her down and start painting everything.
Dano
Dano69c10 is offline   Reply With Quote
Old 09-19-2012, 01:18 PM   #43
VDOG
Grand PooBaa Member
VDOG's Avatar
Originally Posted by Dano69c10 View Post
Hey Vince,
Dano
I understand, im short on cash also, thats why im doing a few things at a time. If I use the 71-72 spindles, I have to buy the upper and lower ball joints, and outer tie rods. Which is not too bad, or I can just get lowered spindles and ball joints as a set for 320. Way too many options.
Old 09-27-2012, 05:39 PM   #44
VDOG
Grand PooBaa Member
VDOG's Avatar
Also thinking of converting from leafs to trailing arms and coils. Just a thought.
Old 10-01-2012, 11:55 AM   #45
Kabwe
Certified Car Nut
Kabwe's Avatar
Well I looked at your build after you bullied me.lol I like the project man its nice. As far as removing the bondo use a heat gun or propane torch with putty knife. I prefer the heat gun if you don't have one you can borrow mine. Now you are not trying to put a lot of heat into the panel, you are only heating it enough so that the bondo loses its adhesiveness. Also another method is air craft paint remover but it takes several applications and I don't like the mess or getting it on my skin which you will as you scrape it off. Let me know.
Kabwe is offline   Reply With Quote
Old 10-01-2012, 02:05 PM   #46
VDOG
Grand PooBaa Member
VDOG's Avatar
Me bully? Of course not. LOL
Thanks for the idea I have a heat gun and will give it a try before I grab another one. Any ideas, suguestions, advice, etc, etc are well received.
Just dont cause trouble. LOL
Old 10-02-2012, 02:03 AM   #47
Kabwe
Certified Car Nut
Kabwe's Avatar
Well if you don't want trouble than you shouldn't be talking to me.
Old 10-02-2012, 12:00 PM   #48
VDOG
Grand PooBaa Member
VDOG's Avatar
LOL!!! I see this is payback for being a pest on your build. LOL
Old 10-18-2012, 05:10 PM   #49
VDOG
Grand PooBaa Member
VDOG's Avatar
Sent the control arms to the powder coater the other day. Want to get the front end done before the rain comes since its sitting on dirt right now.
Old 10-18-2012, 05:49 PM   #50
VDOG
Grand PooBaa Member
VDOG's Avatar
Cleaned off the crossmember. Dont know if im going to send this out to the powder coater or use POR-15 on it. Need to disassemble it also then I can figure out which way im going.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
