Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-20-2012, 10:49 PM   #1
punkrq
Dies as soon as i let off the gas!
I have a 91' blazer full size with 5.7l tbi. it will be easier 2 say what i haven't done, cuz i'm pretty deep with both time, and $ in this thing. it died on me @ a stop light 3 weeks ago, and has only ran 2x since. it will not start unless i stay on the gas peddle, and dies immediately when i let off. i have replaced the fuel pump, and filter, and the entire ignition. help me please!
91 blazer w/ 5.7 tbi, and 700r4
punkrq is offline   Reply With Quote
Old 08-20-2012, 11:10 PM   #2
LEEVON
Chief Head Scratcher
LEEVON's Avatar
Re: Dies as soon as i let off the gas!
TBI is not my thing, but the TPS and IAC sensors commonly have issues. That might help you start Googling. Check out fullsizechevy.com and 73-87chevy.com (CaptainFab over there knows his TBI).
Oh, and welcome!
'87 Silverado ~ '09 Suburban ~ '71 Cheyenne ~ '50 3100 ~ '80 Wife ~ Late model kids
LEEVON is online now   Reply With Quote
Old 08-21-2012, 12:46 AM   #3
punkrq
thank u. i have replaced the iac,tps,cts,oil press sending unit, and the map sensor. they were all fairly innexpensive, and i wasn't overly confident with my testing. the oil press was failing 4 awhile, and when i replaced the ign. module, and pick up coil i had 2 have the distributer out and that gave me easy access to that unit. i also have changed the ign. coil,plugs,cap, and rotor. i have good spray pattern from the injectors, and plenty of pressure from the fuel pump, that i had 2 replace about 6 months ago. i'll check out the other forums also. and again thanks for the advice.
Old 08-21-2012, 12:58 AM   #4
VH Coachworks
VH Coachworks's Avatar
When you start it up and are on the gas, how does the engine act? As in will it idle smooth at a higher rpm while giving it a gas? I was going to say that you should check the ignition coil and the pick up coil but it looks like you've already replaced that!
1949 Chevy 3100 5 window shortbox - soon to be stretched, chopped and Camaro Sub-Framed' "Grandpa Ed I"
1967 Chevy C/10 SWB - 327/3 on the tree "Grandpa Ed II"
1994 GMC K2500 ECSB - 350/4L60E "Mean Green"
- VH Coachworks -
Facebook
67-72 Chevy HD Headlight Harness's For Sale HERE
67-72 Chevy & GMC Ground Strap Kit's For Sale HERE
67-72 Chevy Rear Speaker Enclosures For Sale HERE
67-72 Chevy Power Door Lock Kit For Sale HERE
VH Coachworks is offline   Reply With Quote
Old 08-21-2012, 04:50 AM   #5
MikeyMan
Maybe a vaccuum leak?
My 307 2bbl acted the same way, a vac line came undone and was sucking air.
MikeyMan is offline   Reply With Quote
Old 08-21-2012, 08:14 AM   #6
LEEVON
LEEVON's Avatar
Oooh, thought of something else. The timing advance is run through the computer, there is a brown/white wire that enters the firewall down low on the driver's side, like below the brake booster. If you don't disconnect that whenever you're working on ignition stuff you will blow the 10a fuse and the truck will remain at 0 degrees through all RPM. Check the fuse.
Old 09-04-2012, 01:55 AM   #7
walterbolton
walterbolton's Avatar
exactly what i was thinking, keep it running at a constant rpm as possible and spray brake cleaner on the intake where it mates to the heads and the ends and see if the rpm changes
walterbolton is offline   Reply With Quote
Old 09-06-2012, 05:48 PM   #8
GEARBOXGARAGE
GEARBOXGARAGE's Avatar
Years ago I had an '89 S10 that was having similar issues and it kept throwing out trouble codes. I fixed or replaced the majority of the parts that you had, until it was determined that the computer was fried, not allowing the engine to run properly, hence the trouble codes. Put a new computer in and all the problems went away. Just a thought......
GEARBOXGARAGE is offline   Reply With Quote
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
