#326 |
The 60-66 GMC/Pontiac guy....
Re: Mesquite 1966 C10 - LS3 W/Air Ride
The reason I mentioned it is because the peddles are different.
I ran into this when I went from the V6 to an inline 6 and had to move the bell crank location. It is pretty simple but I don't have a hydraulic setup so I have no idea what the peddle looks like. As far as I know, they all hang the same way. Since you have upgraded your brakes you will need a new setup anyway. I will try to get some photos uploaded as soon as I can.
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
#327 |
Mine is set up for mechanical too.
Probably wont help you any if you are going to put in the hydralic. The yolk under the dash, that your brake pedal and e-brake mount to should already be set up to accept a clutch pedal, just a matter of getting the right hardware for the application you want to use. I can still post pics of mine if you want them though!
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#328 | |
![]() ![]() Join Date: Oct 2011
I don't think it matter hydro or mech. I just need the pedal and the hardware to mount it. I will make the rest. This is what I have now and I would like to se a pic with a clutch installed.
![]() Thanks Quote:
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" ![]() Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
#329 |
Does any after market company make one. If so I haven't found it.
#330 |
Ok fresh off the digital camera for you!
When I got mine from a donor rig at the junk yard, I installed it the very next day while I could still remember how. (I have to do things like that because I really am not as smart as people pretend I am...) Hope these photos help, if you have any questions of course ask, I will answer what I can.
#331 |
Thanks Murph you the man
#332 |
Old and crusty
![]() Join Date: Jan 2009
66Chevymax,
I went the opposite direction, from stick to automatic. I still have the clutch side stuff for some reason. If you want it you can have it. Dean |
#333 |
PM Sent
#334 |
Old and crusty
Craig,
Here's what I have from my old clutch setup. The only thing I couldn't find was the return spring but that is the easy part. I have pictured the whole assembly but I will send you the clutch arm assembly only. You may have to pull the shaft out of your brake arm assembly and clean out the crud from both ends because those 2 plastic bushings pictured on the clutch shaft go in the ends of the brake shaft, then the clutch shaft goes thru the center of the brake shaft. Kinda hard to explain but it will all be clear when you get all the pieces together. If this is what you need I'll ship it to you this week. The complete clutch arm assembly is shown in the last picture. The retainer bracket slips on the knurled end of the shaft and is secured with a bolt and nut. There's a hole in the opposite end of that bracket that secures it to the clutch actuator rod. You can see most of that in McMurphy's photos. Dean Last edited by dean jendro; 04-18-2012 at 10:01 PM. |
#335 |
That's perfect Dean i can't thank you enough. Let me know if I can ever help you
#336 |
any updates?
I feel like I need a fix....lol |
#337 |
I have done very little as of late, work is taking most of my time along with summer things like the pool, yard and lake, mostly work
![]() Should be able to get back to the truck in August. ![]() ![]()
#338 |
![]() Join Date: May 2007
pool & lake sound like great progress to me ( Md = 100 + temp )
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#339 |
Still one of my favorite builds.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#340 |
I didnt want to be obvious about it, but .... I miss you man.
#341 | |
Thanks man, I hope to keep it that way. Same here Murph, I've been checking in now and then, I just haven't posted much.
#342 |
Just found this build, very nice work.
65 short step edited by staff |
#343 |
The issues your facing and figuring out will help me with my on going build! Great work so far and can't wait to see the finished product! I'm fixing to drop an LY6/4L80 into my 65 SWB BBW once I get the frame back from powder coat.
#344 |
Bump...... This is good........
Posted via Mobile Device |
#345 |
I am just starting a 63 build for my brother. He wants to go LS motor... If you have any tips it would be great! By the way, just noticed... don't see any of your photos??? Sup wit dat?
#346 |
60-66 Nut
Pics work for me.......
#347 |
You can see the pics??? All I see are small boxes with an X in them... is my computer messed up again?? I still need those parts Cap.. waiting on my brother... I will be in touch soon
![]() Love this build
#348 | |
Rollin' Old Skool
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#349 |
This build is awesome man, and I like your shop a lot too! Just the kind of build I would like to do someday, gotta sell a 72 Nova first though!
#350 |
Had my computer fixed today. Can see the photos now.
I am doing an ls motor in a 63 (frame is the same as 64-66) what motor mounts and header combo did you end up with? I read about clearance issues but do you have numbers for the final setup? Anyone have any knowledge as to the wires I will need to feed this engine on a 4L80E? ![]()
