Old 12-08-2012, 02:06 AM   #1
bloodybigblock
bloodybigblock's Avatar
99+ disc rear end for 67-72 trucks
Has anyone or do you know of anyone who has a 99+ style disc brake rear end in their 67-72 model truck. I think this would be ideal since they are strong and have disc brakes so no need to a disc brake kit and you can still retain the 6 lug. Anyone have any info on this?
bloodybigblock is offline   Reply With Quote
Old 12-08-2012, 09:36 AM   #2
Clyde65
Clyde65's Avatar
Re: 99+ disc rear end for 67-72 trucks
I think you will need to check the width
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-08-2012, 09:54 AM   #3
bk2life
yeap, narrow it and itll work.. i have a 99 rear disc set up for my colorado. narrowed total of 18inches..
bk2life is offline   Reply With Quote
Old 12-08-2012, 12:13 PM   #4
bloodybigblock
width is 66" over my 62" rearend. Not only could that give me disc brakes but it would make my front to rear track widths close to even and not have to run staggered wheels. Any recommendation on how id do the brake lines? Ive never messed or adapted brake lines, but have some knowledge of changing them. Id also order CPP rear mount kit to weld the perches on. Thanks guys
Old 12-08-2012, 05:36 PM   #5
crazy longhorn
Fabricate till you "puke"
Try to get all the lines/hoses with the diff, for pattern....My 02 has 3 hoses on the rear(1 ea end, & 1 in the center). One of the outer hoses was a dealer only deal, but the other 2 came from Oreillys. You may have to adapt the fitting (from the rear line to center hose), to get the proper threads. The other thing I found, is the alum calipers (with age) tend to stick. Save a few bucks & purchase "loaded calipers" on the rebuild. best of fun, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-08-2012, 06:11 PM   #6
crazy longhorn
1 more thought....that 99 has 16" wheels . A 15" wheel will probably not fit over the caliper. Again,best of fun playin crazyL
Old 12-08-2012, 09:34 PM   #7
bloodybigblock
do you have this style rear end in your old truck? I guess if all else fails i cant make custom brake lines. Im sure this swap would be cheaper then putting a posi and disc brakes on my stock rear end.
Old 12-08-2012, 10:00 PM   #8
Clyde65
Clyde65's Avatar
Someone here sells a kit to put disc brakes on the 12 bolt, I think it's captn fab. Uses impala or? Calipers
Clyde65
Rebuild of Clyde
support our troops!
Old 12-08-2012, 10:54 PM   #9
crazy longhorn
No sir, I have that style rear under my stock 02 silverado? I do know that you are playing with metric fittings tho... too bad you are not closer to my spot in Illinois! I have the calipers(core only), & the lines & hoses & useable rotors.If you were close enough to pick em up, they would be yours for the "takin" (NC). crazyL
Old 12-09-2012, 08:28 PM   #10
clinebarger
Truck 10-bolts come with a Eaton Gov-Loc Posi, Or affectionately known as a Gov-Bomb. Not worth installing in your truck Just to have this happen.........
clinebarger is offline   Reply With Quote
Old 12-10-2012, 12:16 PM   #11
67 Burb
67 Burb's Avatar
OUCH ! ! That diff looks like it needs a few nicks polished out of it.
67 Burb is offline   Reply With Quote
Old 12-10-2012, 02:22 PM   #12
crazy longhorn
That dont look good! I have 1 of those 'gov bombs" in my truck.....I dont crowd it too hard tho (just a daily driver) You can install a True Track, or a clutch style posi in that diff to beef it up . crazyL
Old 12-10-2012, 07:58 PM   #13
bighaas79
Thats some tasty looking carnage.
bighaas79 is offline   Reply With Quote
Old 12-10-2012, 08:29 PM   #14
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
The Right Stuff makes a 6lug disc brake conversion. http://www.getdiscbrakes.com/trd4706
-Automatics win races, 6-speeds impress high school kids
-Save a tree, support your local dragstrip.
-"Failure - The Secret To Success, the idea is that you can fail 100 times as long as you can succeed once" -Takeo Fukui
columbuscarsandcoffee.net and on Facebook
ProStreet68SB is offline   Reply With Quote
Old 12-10-2012, 08:37 PM   #15
clinebarger
I didnt know you had that kind of self control
Bloodybigblock.....Disc brakes are not worth the work to install a 10-bolt under your truck.
If you got to have Disc brakes, CaptainFab makes some brackets to do that to your 12-bolt, Add a Yukon Dura-Grip posi & your in business.
71/72 diffs are wider & will solve the width issue, Buy a core rear & build it up a little at a time.
Old 12-10-2012, 08:54 PM   #16
crazy longhorn
....no issues with the daily driver, but the toys still take the old man back about 40 yrs? Its he!! , being 18yrs old in this 55 yr old body crazyL
Old 12-10-2012, 11:11 PM   #17
shortbed70
shortbed70's Avatar
Lol looks like your diff has the flu!!!!
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 12-10-2012, 11:59 PM   #18
clinebarger
More like the bubonic plague.
Old 12-11-2012, 12:39 AM   #19
crazy longhorn
All jokin aside, I do have to agree with clinebarger....the 12 bolt would be a better build crazyL
Old 12-11-2012, 11:15 AM   #20
Low Elco
Cline- you need a stouter cart! That baby's seen better days!
Low Elco is offline   Reply With Quote
Old 12-12-2012, 09:50 PM   #21
crazy longhorn
Naw....that will "buff out" crazyL
Old 12-13-2012, 12:33 PM   #22
bloodybigblock
what about a 14 bolt rear from a 90s model 3/4 ton?
Old 12-13-2012, 07:43 PM   #23
clinebarger
Still Gov-Loc, Not quite as easy to break, A real Posi carrier is quite expensive for a 9.5" 14-bolt.
