12-03-2012, 09:48 PM | #51 |
Re: Roushinator's 72 C10 Stepside Restore/Build
12-03-2012, 10:05 PM | #52 |
looking good. I cant tell for sure, But it looks like the motor is sitting on old I6 perches. This pushes it back and can cause fitment issues with headers and make the Dist real tight to the firewall. A set of v-8 perches in the foward holes will correct that. Some leave it alone and like the weight moved further back. Something to look into.
12-17-2012, 11:08 AM | #53 |
Got some more work done this weekend.
Plasma cutter was a little disappointing. It is a 110/220 unit. I had it hooked up to 110. I am going to try it on 220 next. Should work better. Oh and we did have it connected to a much larger compressor than the one in the picture.
Ryan... 1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain http://67-72chevytrucks.com/vboard/s...11#post5532411 |
12-17-2012, 11:59 AM | #54 | |
12-17-2012, 12:03 PM | #55 |
Good job so far. Keep up the hard work and you will be done in no time.
12-17-2012, 12:24 PM | #56 | |
I have a friend that is an expert welder (30+ years) he volunteered to come weld them in. He also is going to fix the rear cross member. I found it has 2" crack in it.
12-17-2012, 02:10 PM | #57 |
nice progress.. keep it going..
True |
12-22-2012, 08:31 PM | #58 |
Got more work done today....
Look at these springs!
12-22-2012, 09:16 PM | #59 |
Watch out for your cornhole !
I noticed in your first post on this thread that you were asking about the wheels.
I'd bet money they are Prime brand. Super Shops sold a gillion sets of them in the late 80s in the southern part of the country. I even had a set on my mini truck back in the day. |
12-24-2012, 08:48 PM | #60 |
Got some work done....
Brakes were toast... Had to beat one side off with a hammer. New rear crossmember. 40 years of grease and dirt.... Dirt gone......
12-30-2012, 12:34 PM | #61 |
Looking good on your start of your build.Keep the pictures coming & keep on truckin''
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15. Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e, |
12-30-2012, 01:20 PM | #62 |
Great progress, I am enjoying the frame and suspension work being that my own is requiring a ton of work to make right. I am looking forward to seeing the finished rolling chassis.
01-06-2013, 08:20 PM | #63 |
Did not rebuild the rear end this weekend. Wanted to wait until my rear brakes came in. I did however get a lot of work done...
Bolted new ECE rear cross member in today. Old/bent crossmember compared to new ECE crossmember Drilled holes and bolted in the C Notch kit....
01-06-2013, 08:21 PM | #64 |
Finally got around to mounting my new POL 19 Gal. gas tank.
New best friend. Will never drill metal again with a regular bit.
01-06-2013, 08:52 PM | #65 |
Man of Mini-Talents
You've accomplished a crapton of work. You're about to make the turn where things get more fun.
What route did you decide to go on the cab? Soda blast or ? What's the plan on the front suspension? Keep up the good work.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
01-06-2013, 09:09 PM | #66 |
I am not sure about the cab just yet.... Once i get all this done i can roll in the cab and start digging into it again.
For the front suspension i have CPP tubular upper and lower control arms.
01-12-2013, 07:31 PM | #67 |
Got the notches welded in.... They better be in the right spot because they aren't going to move now....
01-12-2013, 07:37 PM | #68 |
Stick welded with 7018 or am I needing glasses ?
01-12-2013, 08:42 PM | #69 |
The axle c notches were stick welded in using 2 different rods. I can't remember the numbers.
01-12-2013, 08:44 PM | #70 |
Looks like 7018 rod. Its nice to see someone who still has the skill to burn rods as well as pull the trigger on a MIG gun.
01-12-2013, 08:49 PM | #71 |
I cant take credit for that. My friend welded it up for me. He is one of the best.
01-12-2013, 10:09 PM | #72 |
Dirt gone...... [/QUOTE] Ok. I'm having ISSUES with this...how'd you get the 40 years of grime off of there?
2007 VW GTI - SOLD, 2013 Ram 1500 Crew Cab Hemi 4x4 - TRADED (POS), 2006 Silverado 2500 Dirtymax, 2010 Kawasaki ZX-10R (wrecked), 2006 SV650, 2015 ZX-6R 1968 C10 CST LWB "..... Long beds are like the slightly chubbier sisters to the hot chick, still cute with a lot more to like. hahahaha!" - OrtegaMotor |
01-12-2013, 10:32 PM | #73 | |
01-12-2013, 11:53 PM | #74 |
Well alrighty then. Time to push the elbow grease a bit more.
01-13-2013, 07:29 AM | #75 |
Ok. I'm having ISSUES with this...how'd you get the 40 years of grime off of there?[/QUOTE]
I don't know if you have the work environment that can support it, but if you have a "dirty" area where you can work, I can tell you an excellent way. Put the parts on sawhorses and coat them liberally with dollar store cheap oven cleaner. Let it sit 15 minutes or so then respray it with another coat. After another few minutes, hose it off with a garden hose. On real nasty stuff like that rearend, you will probably need to let it dry and repeat the oven cleaner deal again. Perhaps a few times, but it will get it clean. This method is cheap and easy, as long as you have patience to walk by it every so often and spray it again and wait for the chemical to do the work for you. |
