Old 01-04-2013, 10:50 AM   #201
daverod
SSN 706
daverod's Avatar
Re: '49 chevy with s-10
I'm sorry but thats the way I roll. I see stuff I like and I copy it. I have a 4 link on my 66. It works much better than a 3 link. My 52 doesnt really move that much from side to side because I dont raise it very much. I dont think it moves 1/2" to 3/8 from full rise to full drop. I do like how a 4 link keeps the rear diff at the same angle all the time.
daverod is offline   Reply With Quote
Old 01-04-2013, 12:37 PM   #202
Jesse49chevy
Jesse49chevy's Avatar
LOL... it be hard not to follow you, it seems you are doing a great job....
hey just to follow up on the rotors, I called Summit Racing and the guy said he can get me a set of rotors with the Chevy PU pattern for 62.00 each, I also called Helix and the guy sent me information and he can has the ones with both Chevy and Ford (yuk) bolt pattern for 400.00+ a pair....
Semper Fi
Check out my project:
http://67-72chevytrucks.com/vboard/s...d.php?t=559086
Jesse49chevy is offline   Reply With Quote
Old 01-04-2013, 05:12 PM   #203
rollinrooster
rollinrooster's Avatar
Originally Posted by Dirty Doug View Post
I guess I did see those pics now that I looked at them again. Did you make the top bracket ? What brand and number shock is that ? I have a Ride Tech upper that use the eyelet or bolt through type shock but the bracket looks thinner the the S10 frame .
A friend of mine gave me the frt shock mounts, i think they came from suicide doors. I will check on the shock # when i get home.
rollinrooster is offline   Reply With Quote
Old 01-04-2013, 06:03 PM   #204
Kabwe
Certified Car Nut
Kabwe's Avatar
OMG that is a awful lot of money for rotors. I bought my drilled and slotted rotors from Helix (the ones with the dual bolt patterns) and they were only 100 bucks for the pair but that is for a mustang 2 suspension.
Kabwe is offline   Reply With Quote
Old 01-09-2013, 03:20 PM   #205
Jesse49chevy
Hey Rollinrooster, what rear end are you using? is it the stock S-10?
I am trying to decide what to do on mine, i have a 8.8 off a Mustang, I want to run
15 x 10s in the rear, but since I dont have the bed of the truck im afraid it will be to wide. So im thinking of using a S-10 rear end being that i want my truck to have a similar stance to yours.
Semper Fi
Old 01-09-2013, 05:14 PM   #206
rollinrooster
Im running a 9" ford in mine that has been cut down. Do you already have the wheels, If so what is the backspacing on them? Also how wide is your 8.8 mustang rearend? Let me know these few things and i will try to help you out with the correct setup. One more thing....is your s-10 rearend the 2wd or 4wd unit? Ive got a bunch of chassis measurements for these things just need to dig it all up.
Old 01-09-2013, 08:52 PM   #207
Jesse49chevy
No, i dont have the wheels yet, doing some homework. But i want to buy reproduction rally wheels from classic industries. I want to run 15x8 in the front and 15x10 in the rear. The 15x10 come with a 4 1/4 backspace. I just measured the rear end and from mounting point it is 60 3/4. How difficult is it to shorten it? Or what do you suggest? I dont have a S-10 rear end, but was looking to buy one, if i had to.
Semper Fi
Old 03-26-2013, 07:09 PM   #208
rollinrooster
made a filler piece for the gas tank. now just need to weld it in.
Old 03-27-2013, 12:26 AM   #209
oldman3
oldman3's Avatar
Piece looks good, glad to see you back posting, missed ya...Jim
oldman3 is offline   Reply With Quote
Old 03-27-2013, 07:52 AM   #210
rollinrooster
Thanks Jim, ive been working on it some but this winter my kids have kept me hopping with basketball,gymnastics and cheerleading
Old 03-27-2013, 09:24 PM   #211
rollinrooster
Spent some time today welding in the gas neck filler.
Old 03-27-2013, 11:10 PM   #212
Chevette
Chevette's Avatar
You should tell your kids to quit interrupting your progress. Don't they understand how important your build is?
BTW, it's Lookin' Real Good.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 03-30-2013, 10:03 PM   #213
rollinrooster
Thanks... sometimes they just dont understand.
Old 04-30-2013, 09:37 PM   #214
1lo67
1lo67's Avatar
Hey Man where you at on your truck?
1lo67 is offline   Reply With Quote
Old 05-01-2013, 08:07 AM   #215
rollinrooster
Hey man... good to hear from you. Ive got a ton of parts just need to find the time to get everything together. I boought the vintage air front runner and sum more stuff for the motor ( i believe i have almost everything as far as drivetrain except a drive shaft)need to get Ferguson to make me one. Currently im in the middle of getting my driveshaft tunnel made by Buddy Hopson also bought an aluminum radiator from him. Once i get the tunnel done im going to take it over to Chris's shop to get the bottom coated and the firewall / dash painted. You headed to street rod nats this weekend? Feel free to stop by any time.
Old 05-01-2013, 04:12 PM   #216
1lo67
1lo67's Avatar
You will love the Vintage air stuff mine wrks great zero problems.. Buddy is the Man!!!!
I hope to make the NSRA show this wknd (if..IF) I dnt have to work....lol seems that's all I do anymore. i'l stop in one evening when I see the sparks flying from the garage...lol
Old 05-05-2013, 10:59 PM   #217
wood1
1lo67, any pictures your Suburban?? That thing looks badazz....
wood1 is offline   Reply With Quote
Old 01-04-2014, 10:11 PM   #218
rollinrooster
Finally found some time to work on truck again, been busy with new job and family. Started working on drive shaft and tunnel. Also installed new window regulators and bear claw latches. About ready to get dash and firewall painted then hopefully start wiring this thing up
Old 01-05-2014, 10:05 PM   #219
1lo67
1lo67's Avatar
Looking good... You need that out on the road this summer.
Old 01-06-2014, 12:47 AM   #220
youngrodder
youngrodder's Avatar
Nice trans tunnel...I also agree with 1lo67 we need to see this truck on the road this summer.
Keep up the progress...we are watching.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-06-2014, 01:46 PM   #221
rollinrooster
Thanks to both of you.... that's the plan
Old 01-25-2014, 08:55 PM   #222
rollinrooster
Got some time today to work on tunnel, almost finished with it. Have to travel to York PA. next week for work so there wont be much progress hope to get on it good once I get back.
Old 01-25-2014, 09:02 PM   #223
youngrodder
Looks nice. Why dont you just build two tranny humps while you are at it....I could make sure of one. JK
It always feels good to get back at it after a layoff from working on your project.
Marc
Old 01-25-2014, 09:23 PM   #224
1lo67
1lo67's Avatar
Looking good... What size slip is that I spy?
Old 01-26-2014, 08:28 AM   #225
rollinrooster
its just a 12" woodward fab I just bought. Already would like to have a bigger one just cant justify it
