Old 01-18-2013, 02:51 AM   #16
SoCalSlaughter
SoCalSlaughter's Avatar
Re: ECM-B fuse blown, no start!!
Well I was having a problem with the ECMB fuse blowing, and when it would blow the ECM would lose all codes, but I have fixed a few grounds and the ECMB fuse doesnt blow anymore, still no prime or run from pump, turn key on, engine light flashes once then stays on and I can hear the fuel pump relay click.. then a few seconds later click again. But the night before the truck stopped running I had gotten the code 42. Then just shut off in reverse and pump will no run. Everything else seems to work. maybe the fuse block inside had bad connections?
SoCalSlaughter is offline   Reply With Quote
ecm, ecmb, fuel pump, no start
